What is the absolute maximum voltage rating on CT pins?
Datasheet only have the differential voltage range and this note:
I want to know if the MC33772 is able to survive a short to battery (12V) in any of the CT pins.
Solved! Go to Solution.
Please note that 6.7V is valid under permanent operation, and even in such case some margin has been taken (the value might have been higher).
