today I tried to get ltib running the second day - without success.
I used it on Ubuntu 8.04, 9.04 and 10.04.
It's always the same error "Failed building dtc".
I installed LTIB (everythings ok), installed the packages needed and tried to execute ./ltib.
It works about half an hour and then stops with the error.
The log-file:
Executing(%build): /bin/sh -e /home/maa/LTIB/ltib-e500mc-20091218/tmp/rpm-tmp.16839+ umask 022+ cd /opt/freescale/ltib/usr/src/rpm/BUILD+ cd dtc-1.2.0+ [ host == host ][: 1: ==: unexpected operator+ /usr/bin/make CC=/usr/bin/gcc -mcpu=host -msoft-float -idirafter //usr/include AS=/usr/bin/gcc -mcpu=host -msoft-float -idirafter //usr/include LD=/usr/bin/gcc -mcpu=host -msoft-float -C /opt/freescale/ltib/usr/src/rpm/BUILD/dtc-1.2.0make: Entering directory `/opt/freescale/ltib/usr/src/rpm/BUILD/dtc-1.2.0' DEP tests/dumptrees.c`-mcpu=' is deprecated. Use `-mtune=' or '-march=' instead.tests/dumptrees.c:0: error: bad value (host) for -mtune= switch DEP tests/trees.S`-mcpu=' is deprecated. Use `-mtune=' or '-march=' instead.tests/trees.S:0: error: bad value (host) for -mtune= switch DEP tests/testutils.c`-mcpu=' is deprecated. Use `-mtune=' or '-march=' instead.tests/testutils.c:0: error: bad value (host) for -mtune= switch DEP tests/value-labels.c`-mcpu=' is deprecated. Use `-mtune=' or '-march=' instead.tests/value-labels.c:0: error: bad value (host) for -mtune= switch DEP tests/asm_tree_dump.c`-mcpu=' is deprecated. Use `-mtune=' or '-march=' instead.tests/asm_tree_dump.c:0: error: bad value (host) for -mtune= switch DEP tests/truncated_property.c`-mcpu=' is deprecated. Use `-mtune=' or '-march=' instead.tests/truncated_property.c:0: error: bad value (host) for -mtune= switch DEP tests/path_offset_aliases.c`-mcpu=' is deprecated. Use `-mtune=' or '-march=' instead.tests/path_offset_aliases.c:0: error: bad value (host) for -mtune= switch DEP tests/add_subnode_with_nops.c`-mcpu=' is deprecated. Use `-mtune=' or '-march=' instead.tests/add_subnode_with_nops.c:0: error: bad value (host) for -mtune= switch DEP tests/dtbs_equal_ordered.c`-mcpu=' is deprecated. Use `-mtune=' or '-march=' instead.tests/dtbs_equal_ordered.c:0: error: bad value (host) for -mtune= switch DEP tests/incbin.c`-mcpu=' is deprecated. Use `-mtune=' or '-march=' instead.tests/incbin.c:0: error: bad value (host) for -mtune= switch DEP tests/boot-cpuid.c`-mcpu=' is deprecated. Use `-mtune=' or '-march=' instead.tests/boot-cpuid.c:0: error: bad value (host) for -mtune= switch DEP tests/path-references.c`-mcpu=' is deprecated. Use `-mtune=' or '-march=' instead.tests/path-references.c:0: error: bad value (host) for -mtune= switch DEP tests/references.c`-mcpu=' is deprecated. Use `-mtune=' or '-march=' instead.tests/references.c:0: error: bad value (host) for -mtune= switch DEP tests/string_escapes.c`-mcpu=' is deprecated. Use `-mtune=' or '-march=' instead.tests/string_escapes.c:0: error: bad value (host) for -mtune= switch DEP tests/del_node.c`-mcpu=' is deprecated. Use `-mtune=' or '-march=' instead.tests/del_node.c:0: error: bad value (host) for -mtune= switch DEP tests/del_property.c`-mcpu=' is deprecated. Use `-mtune=' or '-march=' instead.tests/del_property.c:0: error: bad value (host) for -mtune= switch DEP tests/setprop.c`-mcpu=' is deprecated. Use `-mtune=' or '-march=' instead.tests/setprop.c:0: error: bad value (host) for -mtune= switch DEP tests/set_name.c`-mcpu=' is deprecated. Use `-mtune=' or '-march=' instead.tests/set_name.c:0: error: bad value (host) for -mtune= switch DEP tests/rw_tree1.c`-mcpu=' is deprecated. Use `-mtune=' or '-march=' instead.tests/rw_tree1.c:0: error: bad value (host) for -mtune= switch DEP tests/open_pack.c`-mcpu=' is deprecated. Use `-mtune=' or '-march=' instead.tests/open_pack.c:0: error: bad value (host) for -mtune= switch DEP tests/nopulate.c`-mcpu=' is deprecated. Use `-mtune=' or '-march=' instead.tests/nopulate.c:0: error: bad value (host) for -mtune= switch DEP tests/mangle-layout.c`-mcpu=' is deprecated. Use `-mtune=' or '-march=' instead.tests/mangle-layout.c:0: error: bad value (host) for -mtune= switch DEP tests/move_and_save.c`-mcpu=' is deprecated. Use `-mtune=' or '-march=' instead.tests/move_and_save.c:0: error: bad value (host) for -mtune= switch DEP tests/sw_tree1.c`-mcpu=' is deprecated. Use `-mtune=' or '-march=' instead.tests/sw_tree1.c:0: error: bad value (host) for -mtune= switch DEP tests/nop_node.c`-mcpu=' is deprecated. Use `-mtune=' or '-march=' instead.tests/nop_node.c:0: error: bad value (host) for -mtune= switch DEP tests/nop_property.c`-mcpu=' is deprecated. Use `-mtune=' or '-march=' instead.tests/nop_property.c:0: error: bad value (host) for -mtune= switch DEP tests/setprop_inplace.c`-mcpu=' is deprecated. Use `-mtune=' or '-march=' instead.tests/setprop_inplace.c:0: error: bad value (host) for -mtune= switch DEP tests/notfound.c`-mcpu=' is deprecated. Use `-mtune=' or '-march=' instead.tests/notfound.c:0: error: bad value (host) for -mtune= switch DEP tests/get_alias.c`-mcpu=' is deprecated. Use `-mtune=' or '-march=' instead.tests/get_alias.c:0: error: bad value (host) for -mtune= switch DEP tests/node_offset_by_compatible.c`-mcpu=' is deprecated. Use `-mtune=' or '-march=' instead.tests/node_offset_by_compatible.c:0: error: bad value (host) for -mtune= switch DEP tests/node_check_compatible.c`-mcpu=' is deprecated. Use `-mtune=' or '-march=' instead.tests/node_check_compatible.c:0: error: bad value (host) for -mtune= switch DEP tests/node_offset_by_phandle.c`-mcpu=' is deprecated. Use `-mtune=' or '-march=' instead.tests/node_offset_by_phandle.c:0: error: bad value (host) for -mtune= switch DEP tests/node_offset_by_prop_value.c`-mcpu=' is deprecated. Use `-mtune=' or '-march=' instead.tests/node_offset_by_prop_value.c:0: error: bad value (host) for -mtune= switch DEP tests/parent_offset.c`-mcpu=' is deprecated. Use `-mtune=' or '-march=' instead.tests/parent_offset.c:0: error: bad value (host) for -mtune= switch DEP tests/supernode_atdepth_offset.c`-mcpu=' is deprecated. Use `-mtune=' or '-march=' instead.tests/supernode_atdepth_offset.c:0: error: bad value (host) for -mtune= switch DEP tests/get_path.c`-mcpu=' is deprecated. Use `-mtune=' or '-march=' instead.tests/get_path.c:0: error: bad value (host) for -mtune= switch DEP tests/get_phandle.c`-mcpu=' is deprecated. Use `-mtune=' or '-march=' instead.tests/get_phandle.c:0: error: bad value (host) for -mtune= switch DEP tests/getprop.c`-mcpu=' is deprecated. Use `-mtune=' or '-march=' instead.tests/getprop.c:0: error: bad value (host) for -mtune= switch DEP tests/get_name.c`-mcpu=' is deprecated. Use `-mtune=' or '-march=' instead.tests/get_name.c:0: error: bad value (host) for -mtune= switch DEP tests/path_offset.c`-mcpu=' is deprecated. Use `-mtune=' or '-march=' instead.tests/path_offset.c:0: error: bad value (host) for -mtune= switch DEP tests/subnode_offset.c`-mcpu=' is deprecated. Use `-mtune=' or '-march=' instead.tests/subnode_offset.c:0: error: bad value (host) for -mtune= switch DEP tests/find_property.c`-mcpu=' is deprecated. Use `-mtune=' or '-march=' instead.tests/find_property.c:0: error: bad value (host) for -mtune= switch DEP tests/root_node.c`-mcpu=' is deprecated. Use `-mtune=' or '-march=' instead.tests/root_node.c:0: error: bad value (host) for -mtune= switch DEP tests/get_mem_rsv.c`-mcpu=' is deprecated. Use `-mtune=' or '-march=' instead.tests/get_mem_rsv.c:0: error: bad value (host) for -mtune= switch DEP libfdt/fdt_strerror.c`-mcpu=' is deprecated. Use `-mtune=' or '-march=' instead.libfdt/fdt_strerror.c:0: error: bad value (host) for -mtune= switch DEP libfdt/fdt_rw.c`-mcpu=' is deprecated. Use `-mtune=' or '-march=' instead.libfdt/fdt_rw.c:0: error: bad value (host) for -mtune= switch DEP libfdt/fdt_sw.c`-mcpu=' is deprecated. Use `-mtune=' or '-march=' instead.libfdt/fdt_sw.c:0: error: bad value (host) for -mtune= switch DEP libfdt/fdt_wip.c`-mcpu=' is deprecated. Use `-mtune=' or '-march=' instead.libfdt/fdt_wip.c:0: error: bad value (host) for -mtune= switch DEP libfdt/fdt_ro.c`-mcpu=' is deprecated. Use `-mtune=' or '-march=' instead.libfdt/fdt_ro.c:0: error: bad value (host) for -mtune= switch DEP libfdt/fdt.c`-mcpu=' is deprecated. Use `-mtune=' or '-march=' instead.libfdt/fdt.c:0: error: bad value (host) for -mtune= switch DEP ftdump.c`-mcpu=' is deprecated. Use `-mtune=' or '-march=' instead.ftdump.c:0: error: bad value (host) for -mtune= switch LEX convert-dtsv0-lexer.lex.c DEP convert-dtsv0-lexer.lex.c`-mcpu=' is deprecated. Use `-mtune=' or '-march=' instead.convert-dtsv0-lexer.lex.c:0: error: bad value (host) for -mtune= switch DEP util.c`-mcpu=' is deprecated. Use `-mtune=' or '-march=' instead.util.c:0: error: bad value (host) for -mtune= switch DEP srcpos.c`-mcpu=' is deprecated. Use `-mtune=' or '-march=' instead.srcpos.c:0: error: bad value (host) for -mtune= switch BISON dtc-parser.tab.c DEP dtc-parser.tab.c`-mcpu=' is deprecated. Use `-mtune=' or '-march=' instead.dtc-parser.tab.c:0: error: bad value (host) for -mtune= switch LEX dtc-lexer.lex.c DEP dtc-lexer.lex.c`-mcpu=' is deprecated. Use `-mtune=' or '-march=' instead.dtc-lexer.lex.c:0: error: bad value (host) for -mtune= switch DEP treesource.c`-mcpu=' is deprecated. Use `-mtune=' or '-march=' instead.treesource.c:0: error: bad value (host) for -mtune= switch DEP livetree.c`-mcpu=' is deprecated. Use `-mtune=' or '-march=' instead.livetree.c:0: error: bad value (host) for -mtune= switch DEP fstree.c`-mcpu=' is deprecated. Use `-mtune=' or '-march=' instead.fstree.c:0: error: bad value (host) for -mtune= switch DEP flattree.c`-mcpu=' is deprecated. Use `-mtune=' or '-march=' instead.flattree.c:0: error: bad value (host) for -mtune= switch DEP dtc.c`-mcpu=' is deprecated. Use `-mtune=' or '-march=' instead.dtc.c:0: error: bad value (host) for -mtune= switch DEP data.c`-mcpu=' is deprecated. Use `-mtune=' or '-march=' instead.data.c:0: error: bad value (host) for -mtune= switch DEP checks.c`-mcpu=' is deprecated. Use `-mtune=' or '-march=' instead.checks.c:0: error: bad value (host) for -mtune= switch CC srcpos.o`-mcpu=' is deprecated. Use `-mtune=' or '-march=' instead.srcpos.c:1: error: bad value (host) for -mtune= switchmake: *** [srcpos.o] Error 1make: Leaving directory `/opt/freescale/ltib/usr/src/rpm/BUILD/dtc-1.2.0'error: Bad exit status from /home/maa/LTIB/ltib-e500mc-20091218/tmp/rpm-tmp.16839 (%build)RPM build errors: Bad exit status from /home/maa/LTIB/ltib-e500mc-20091218/tmp/rpm-tmp.16839 (%build)Build time for dtc: 2 secondsFailed building dtcDied at ./ltib line 1380.traceback: main::build_host_rpms:1380 main::host_checks:1435 main:542Started: Mon May 3 17:59:22 2010Ended: Mon May 3 18:24:34 2010Elapsed: 1512 secondsThese packages failed to build:dtcBuild Failed
Can someone help me to get it running?
Seems to me that it's an ubuntu problem, cause i had no problems using it with suse 9.0!?
But the FAQ-file in the subdirectory /doc/ says that it should run with ubuntu 8.04!
Thanks in advance for every hint!
Solved! Go to Solution.
When ltib tries to build the host side packages, it invokes "rpmbuild". This tool apparently creates temporary scripts which then do the work. One of these temp scripts created for the host side dtc build contains a line:
if [ $PLATFORM == host ]
and "$PLATFORM" expands to "host".
As it turns out though, Ubuntu 9.04 uses dash as default "/bin/sh" link for running the script, which does not like that script line at all, complains about it, takes the wrong path in the script, and causes the build failure.
+ [ host == host ]
[: 1: host: unexpected operator
On the Ubuntu web is the following:
The [ command (a.k.a. test) must be used carefully in portable scripts. A very common pitfall is to use the == operator, which is a bashism; use = instead.
The easiest way to work around this problem invoke the /bin/bash shell and then run ltib. I hope this helps.
Ron
It seems that noone knows about this error!?
+ [ host == host ]
Ron
That was the hint I needed.
The solution was to edit the file "dtc-common.tmpl" in the subdirectory INSTALLDIR_OF_LTIB/dist/lfs-5.1/dtc/ .
I just changed "if [ $PLATFORM == host ]" to "if [ $PLATFORM = host ]" - now it runs!
Thanks a lot, your my great savior !
