Kernel module error occurred when running APP on EVB
1,576件の閲覧回数
BWStart
EVB can be started from SDcard, and oal_driver. ko needs to be loaded when running example.  Run the command  modprobe oal_driver according to the description of User Manual, and an error is reported:
Modprobe :FATAL:Module oal_driver.ko not found in driectory /lib/modules/5.10.109-rt65+ g0Bace7fde5f5, run the command  depmod Oal_driver. ko and another error is reported:
DEPMOD: ERROR: Bad version passed oal_driver.ko.
How do I resolve the problem?
0 返答(返信)
