JN5168 MAC RETRIES PROBLEM
mesut_yilmaz
Hello to everyone
I am working on the jn5168 microcontroller platform. I have a problem.
I am sending package with rf. Mac layer tries 4 times when I do not receive ACK from the package I send.
Guess the default value is 4.
I want to send 1 times when no ACK.
I am analyzing the signal. The package is send 4 times as show in the picture.
How can I fix this.
The code I wrote in the picture below looks.  I am trying to set with this function but not working.
When I debug, I see that I can't set. (u8Retsies = 1).
This function not working. Do you think there is an error in this function.
  • RF
mesut_yilmaz
Hi Sebastian
I print the value but the function still does not work.
Best Regards.
Sebastian_Del_Rio
Hi Mesut,
Could you please try performing a project cleanup and trying again?
Also, could you please try printing the value itself, instead of a message? Just to be sure of what value is being set in the MAC's configuration.
If that doesn't work, could you please try the MAC_MAX_FRAME_RETRIES macro In your corresponding MAC header file?
Please let me know of your findings.
Sebastian
Sebastian_Del_Rio
Hi Mesut, I hope you're doing well!
Per 802.15.4 specification, the value for macMaxFrameRetries has to be an integer between 0 and 7, with a default of 3 (this is why the ACK is being sent 4 times).
When sending an MLME Request, you should also be setting the u8ParamLength value with the size of the MAC_MlmeReqStart_s structure, like so:
sMlmeReqRsp.u8ParamLength = sizeof(MAC_MlmeReqStart_s);
Along with the attribute, and value.
Could you please try adding that?
Please let me know if you still have issues.
Sebastian
mesut_yilmaz
Hi Sebastian
Thank you for answer
I did what you sait. Unfortunately , İt is the same
Sebastian_Del_Rio
Hi Mesut,
Could you please try printing the value to see if it's changing accordingly?
Also, could you please try doing a cleanup of your project and rebuilding it?
Sebastian
