Issue with dpdk-l2fwd-crypto Application SW on Ubuntu 20.04 PC
3,170 次查看
sheikfaaruk
I am testing dpdk application in PC with PCI-E Dual-RJ45 gigabit NIC card to develop a network based application. I have started my project with dpdk 21.08 and Codewarrior IDE.
PC details :
uname -a
Linux mglocadmin-ThinkCentre-M73 5.15.0-105-generic #115~20.04.1-Ubuntu SMP Mon Apr 15 17:33:04 UTC 2024 x86_64 x86_64 x86_64 GNU/Linux
The following steps to install DPDK (Data Plane Development Kit) on Ubuntu 20.04:
sudo apt update
sudo apt install build-essential meson python3-pyelftools libnuma-dev pkgconf
wget https://fast.dpdk.org/rel/dpdk-21.08.tar.xz
tar -xf dpdk-21.08.tar.xz
meson build
ninja -C build
meson -Dexamples=all build
sudo ninja install
sudo ldconfig
Setup hugepage in PC:
mkdir -p /dev/hugepages
mountpoint -q /dev/hugepages || mount -t hugetlbfs nodev /dev/hugepages
echo 64 > /sys/devices/system/node/node0/hugepages/hugepages-2048kB/nr_hugepages
Setup NIC card in PC:
sudo ifconfig enp2s0f1 down
sudo ifconfig enp2s0f0 down
cd /<Path>/dpdk-21.08/usertools/
sudo modprobe uio
sudo modprobe uio_pci_generic
sudo dpdk-devbind.py -b uio_pci_generic 02:00.0
sudo dpdk-devbind.py -b uio_pci_generic 02:00.1
dpdk-devbind.py -s
Log "dpdk-devbind.py -s":
Network devices using DPDK-compatible driver
0000:02:00.0 '82571EB/82571GB Gigabit Ethernet Controller D0/D1 (copper applications) 105e' drv=uio_pci_generic unused=e1000e,vfio-pci
0000:02:00.1 '82571EB/82571GB Gigabit Ethernet Controller D0/D1 (copper applications) 105e' drv=uio_pci_generic unused=e1000e,vfio-pci
Network devices using kernel driver
0000:03:00.0 'RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller 8168' if=enp3s0 drv=r8169 unused=vfio-pci,uio_pci_generic *Active*
cd /<PATH>/dpdk-21.08/build/examples
sudo ./dpdk-l2fwd -c 0x3 -n 4 -- -p 0x3 -q 8 --no-mac-updating
Openssl and cryptodev details:
mglocadmin@mglocadmin$ sudo modprobe cryptodev
[sudo] password for mglocadmin:
mglocadmin@mglocadmin$ openssl version
OpenSSL 1.1.1f 31 Mar 2020
mglocadmin@mglocadmin$ ls /dev/crypto
/dev/crypto
NOTE : DPDK-L2fwd application is working
But ,I am unable to get dpdk-l2fwd-crypto to function properly on my Ubuntu 20.04 system. I've checked the dependencies, ensured that DPDK is properly configured, and attempted various troubleshooting steps, but to no avail.
ERROR log:
sudo ./dpdk-l2fwd-crypto -l 1 -n 2 --vdev "crypto_openssl0" --vdev "crypto_openssl1" -- -p 0x3 --chain CIPHER_ONLY --cdev_type SW --cipher_algo aes-cbc --cipher_op ENCRYPT --cipher_key 00:01:02:03:04:05:06:07:08:09:0a:0b:0c:0d:0e:0f --cipher_iv 00:01:02:03:04:05:06:07:08:09:0a:0b:0c:0d:0e:0f --no-mac-updating
EAL: Detected 4 lcore(s)
EAL: Detected 1 NUMA nodes
EAL: Detected static linkage of DPDK
EAL: failed to parse device "crypto_openssl0"
EAL: Unable to parse device 'crypto_openssl0'
EAL: Error - exiting with code: 1
Cause: Invalid EAL arguments
kindly help us to resolve this issue.
3,056 次查看
yipingwang
After configuring PKG_CONFIG_PATH, you need to recompiling DPDK with "meson arm64-build" command.
For details, please refer to section "Compiling DPDK using meson" in LSDK 21.08 user manual.
5 回复数
3,121 次查看
yipingwang
Can you please check whether DPDK is being compiled with "openssl" library.
Below path is must to compile DPDK with openssl:
export PKG_CONFIG_PATH=<OpenSSL lib path>/lib/pkgconfig:$PKG_CONFIG_PATH
Please refer to the following line in flexbuild_lsdk2108_github/packages/apps/networking/dpdk.mk
export PKG_CONFIG_PATH=$(DESTDIR)/usr/local/lib/pkgconfig:$(PKG_CONFIG_PATH) && \
3,114 次查看
sheikfaaruk
Thank you for reply @yipingwang ...
But I was tried to build and run dpdk-l2fwd-crypto application in PC .so I am directly install DPDK not with flex-builder.
Is there any configuration in DPDK i need to change or modify for enable openssl ?
标记 (1)
3,067 次查看
yipingwang
As I mentioned previously, please execute the following before building DPDK.
3,062 次查看
sheikfaaruk
The step which i followed is below :
mglocadmin@mglocadmin-ThinkCentre-M73:~/NIC/dpdk-21.08$ export PKG_CONFIG_PATH=/usr/local/ssl/lib/pkgconfig:$PKG_CONFIG_PATH
mglocadmin@mglocadmin-ThinkCentre-M73:~/NIC/dpdk-21.08$ cd build/
mglocadmin@mglocadmin-ThinkCentre-M73:~/NIC/dpdk-21.08/build$ sudo ninja install
mglocadmin@mglocadmin-ThinkCentre-M73:~/NIC/dpdk-21.08/build$ cd examples/
mglocadmin@mglocadmin-ThinkCentre-M73:~/NIC/dpdk-21.08/build/examples$ sudo modprobe cryptodev
mglocadmin@mglocadmin-ThinkCentre-M73:~/NIC/dpdk-21.08/build/examples$ ls /dev/crypto
/dev/crypto
mglocadmin@mglocadmin-ThinkCentre-M73:~/NIC/dpdk-21.08/build/examples$ openssl engine
(rdrand) Intel RDRAND engine
(dynamic) Dynamic engine loading support
mglocadmin@mglocadmin-ThinkCentre-M73:~/NIC/dpdk-21.08/build/examples$ sudo ./dpdk-l2fwd-crypto -l 1 -n 2 --vdev "crypto_openssl0" --vdev "crypto_openssl1" -- -p 0x3 --chain CIPHER_ONLY --cdev_type SW --cipher_algo aes-cbc --cipher_op ENCRYPT --cipher_key 00:01:02:03:04:05:06:07:08:09:0a:0b:0c:0d:0e:0f --cipher_iv 00:01:02:03:04:05:06:07:08:09:0a:0b:0c:0d:0e:0f --no-mac-updating
Still same issue @yipingwang
3,057 次查看
yipingwang
%3CLINGO-SUB%20id%3D%22lingo-sub-1854492%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EUbuntu%2020.04%20PC%20%E4%B8%8A%E7%9A%84%20dpdk-l2fwd-crypto%20%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E8%BD%AF%E4%BB%B6%E9%97%AE%E9%A2%98%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1854492%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%20PCI-E%20%E5%8F%8C%20RJ45%20%E5%8D%83%E5%85%86%E7%BD%91%E5%8D%A1%E5%9C%A8%20PC%20%E4%B8%8A%E6%B5%8B%E8%AF%95%20dpdk%20%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%EF%BC%8C%E4%BB%A5%E5%BC%80%E5%8F%91%E5%9F%BA%E4%BA%8E%E7%BD%91%E7%BB%9C%E7%9A%84%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E3%80%82%E6%88%91%E5%B7%B2%E7%BB%8F%E4%BD%BF%E7%94%A8%20dpdk%2021.08%20%E5%92%8C%20Codewarrior%20IDE%20%E5%BC%80%E5%A7%8B%E4%BA%86%E6%88%91%E7%9A%84%E9%A1%B9%E7%9B%AE%E3%80%82%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E7%94%B5%E8%84%91%E8%AF%A6%E6%83%85%EF%BC%9A%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3Euname%20-a%3CBR%20%2F%3E%20Linux%20mglocadmin-ThinkCentre-M73%205.15.0-105-%E9%80%9A%E7%94%A8%23115~20.04.1-UbuntuSMP%20%E5%91%A8%E4%B8%80%204%E6%9C%88%2015%E6%97%A5%2017%3A33%3A04%20UTC%202024%20x86_64%20x86_64%20x86_64%20GNU%2FLinux%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E5%9C%A8%20Ubuntu%2020.04%20%E4%B8%8A%E5%AE%89%E8%A3%85%20DPDK%EF%BC%88%E6%95%B0%E6%8D%AE%E5%B9%B3%E9%9D%A2%E5%BC%80%E5%8F%91%E5%A5%97%E4%BB%B6%EF%BC%89%E7%9A%84%E6%AD%A5%E9%AA%A4%E5%A6%82%E4%B8%8B%EF%BC%9A%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%20sudo%20apt%E6%9B%B4%E6%96%B0%3CBR%20%2F%3Esudo%20apt%20install%20build-essential%20meson%20python3-pyelftools%20libnuma-dev%20pkgconf%3CBR%20%2F%3E%20wget%20%3CA%20href%3D%22https%3A%2F%2Ffast.dpdk.org%2Frel%2Fdpdk-21.08.tar.xz%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Ffast.dpdk.org%2Frel%2Fdpdk-21.08.tar.xz%3C%2FA%3E%3CBR%20%2F%3Etar%20-xf%20dpdk-21.08.tar.xz%3CBR%20%2F%3E%E4%BB%8B%E5%AD%90%E6%9E%84%E5%BB%BA%3CBR%20%2F%3Eninja-C%E6%9E%84%E5%BB%BA%3CBR%20%2F%3Emeson%20-Dexamples%3Dall%20build%3CBR%20%2F%3E%20sudo%20ninja%20%E5%AE%89%E8%A3%85%3CBR%20%2F%3Esudo%20ldconfig%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E5%9C%A8PC%E4%B8%8A%E8%AE%BE%E7%BD%AE%E5%A4%A7%E9%A1%B5%E9%9D%A2%EF%BC%9A%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3Emkdir%20-p%20%2Fdev%2Fhugepages%3CBR%20%2F%3E%E6%8C%82%E8%BD%BD%E7%82%B9%20-q%20%2Fdev%2Fhugepages%20%7C%7C%20mount%20-t%20hugetlbfs%20nodev%20%2Fdev%2Fhugepages%3CBR%20%2F%3E%20echo%2064%20%26gt%3B%20%2Fsys%2Fdevices%2Fsystem%2Fnode%2Fnode0%2Fhugepages%2Fhugepages-2048kB%2Fnr_hugepages%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E5%9C%A8PC%E4%B8%8A%E5%AE%89%E8%A3%85%E7%BD%91%E5%8D%A1%EF%BC%9A%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3Esudo%20ifconfig%20enp2s0f1%20down%3CBR%20%2F%3Esudo%20ifconfig%20enp2s0f0%20down%3C%2FP%3E%3CP%3Ecd%20%2F%3CPATH%3E%20%2Fdpdk-21.08%2Fusertools%2F%3CBR%20%2F%3Esudo%20modprobe%20uio%3CBR%20%2F%3E%20sudo%20modprobe%20uio_pci_generic%3CBR%20%2F%3E%20sudo%20dpdk-devbind.py%20-b%20uio_pci_generic%2002%3A00.0%3CBR%20%2F%3Esudo%20dpdk-devbind.py%20-b%20uio_pci_generic%2002%3A00.1%3CBR%20%2F%3Edpdk-devbind.py%20-s%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSTRONG%3E%E8%AE%B0%E5%BD%95%E2%80%9Cdpdk-devbind.py%20-s%E2%80%9D%EF%BC%9A%3C%2FSTRONG%3E%3CBR%20%2F%3E%E4%BD%BF%E7%94%A8DPDK%E5%85%BC%E5%AE%B9%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E7%9A%84%E7%BD%91%E7%BB%9C%E8%AE%BE%E5%A4%87%3CBR%20%2F%3E0000%3A02%3A00.0%20'82571EB%2F82571GB%20%E5%8D%83%E5%85%86%E4%BB%A5%E5%A4%AA%E7%BD%91%E6%8E%A7%E5%88%B6%E5%99%A8%20D0%2FD1%EF%BC%88%E9%93%9C%E5%BA%94%E7%94%A8%EF%BC%89105e'%20drv%3Duio_pci_generic%20unused%3De1000e%2Cvfio-pci%3CBR%20%2F%3E%200000%3A02%3A00.1%20'82571EB%2F82571GB%20%E5%8D%83%E5%85%86%E4%BB%A5%E5%A4%AA%E7%BD%91%E6%8E%A7%E5%88%B6%E5%99%A8%20D0%2FD1%EF%BC%88%E9%93%9C%E5%BA%94%E7%94%A8%EF%BC%89105e'%20drv%3Duio_pci_generic%20unused%3De1000e%2Cvfio-pci%3CBR%20%2F%3E%E4%BD%BF%E7%94%A8%E5%86%85%E6%A0%B8%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E7%9A%84%E7%BD%91%E7%BB%9C%E8%AE%BE%E5%A4%87%3CBR%20%2F%3E0000%EF%BC%9A03%EF%BC%9A00.0%20'RTL8111%2F8168%2F8411%20PCI%20Express%20%E5%8D%83%E5%85%86%E4%BB%A5%E5%A4%AA%E7%BD%91%E6%8E%A7%E5%88%B6%E5%99%A8%208168'%20if%3Denp3s0%20drv%3Dr8169%20unused%3Dvfio-pci%2Cuio_pci_generic%20*Active*%3CBR%20%2F%3E%3CBR%20%2F%3E%20cd%20%2F%3CPATH%3E%2Fdpdk-21.08%2Fbuild%2Fexamples%3CBR%20%2F%3Esudo%20.%2Fdpdk-l2fwd-c%200x3%20-n%204%20--%20-p%200x3%20-q%208%20--%E6%97%A0mac%E6%9B%B4%E6%96%B0%3C%2FPATH%3E%3C%2FPATH%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3EOpenssl%20%E5%92%8C%20cryptodev%20%E8%AF%A6%E7%BB%86%E4%BF%A1%E6%81%AF%EF%BC%9A%3C%2FSTRONG%3E%3CBR%20%2F%3E%20mglocadmin%40mglocadmin%24%20sudo%20modprobe%20cryptodev%3CBR%20%2F%3E%20%5Bsudo%5D%20mglocadmin%20%E7%9A%84%E5%AF%86%E7%A0%81%EF%BC%9A%3CBR%20%2F%3E%20mglocadmin%40mglocadmin%24%20openssl%20%E7%89%88%E6%9C%AC%3CBR%20%2F%3EOpenSSL%201.1.1f2020%E5%B9%B43%E6%9C%8831%E6%97%A5%3CBR%20%2F%3Emglocadmin%40mglocadmin%24%20ls%20%2Fdev%2Fcrypto%3CBR%20%2F%3E%20%2Fdev%2Fcrypto%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E6%B3%A8%E6%84%8F%EF%BC%9ADPDK-L2fwd%20%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E6%AD%A3%E5%9C%A8%E8%BF%90%E8%A1%8C%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E4%BD%86%E6%98%AF%EF%BC%8C%E6%88%91%E6%97%A0%E6%B3%95%E8%AE%A9%20dpdk-l2fwd-crypto%20%E5%9C%A8%E6%88%91%E7%9A%84%20Ubuntu%2020.04%20%E7%B3%BB%E7%BB%9F%E4%B8%8A%E6%AD%A3%E5%B8%B8%E8%BF%90%E8%A1%8C%E3%80%82%E6%88%91%E6%A3%80%E6%9F%A5%E4%BA%86%E4%BE%9D%E8%B5%96%E5%85%B3%E7%B3%BB%EF%BC%8C%E7%A1%AE%E4%BF%9D%20DPDK%20%E9%85%8D%E7%BD%AE%E6%AD%A3%E7%A1%AE%EF%BC%8C%E5%B9%B6%E5%B0%9D%E8%AF%95%E4%BA%86%E5%90%84%E7%A7%8D%E6%95%85%E9%9A%9C%E6%8E%92%E9%99%A4%E6%AD%A5%E9%AA%A4%EF%BC%8C%E4%BD%86%E6%97%A0%E6%B5%8E%E4%BA%8E%E4%BA%8B%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSTRONG%3E%E9%94%99%E8%AF%AF%E6%97%A5%E5%BF%97%EF%BC%9A%3C%2FSTRONG%3E%3CBR%20%2F%3E%20sudo%20.%2Fdpdk-l2fwd-crypto-l%201%20-n%202%20--vdev%E2%80%9Ccrypto_openssl0%E2%80%9D--vdev%E2%80%9Ccrypto_openssl1%E2%80%9D---%20-p%200x3%20--chain%20CIPHER_ONLY%20--cdev_type%20SW%20--cipher_algo%20aes-cbc%20--cipher_op%20ENCRYPT%20--cipher_key%2000%3A01%3A02%3A03%3A04%3A05%3A06%3A07%3A08%3A09%3A0a%3A0b%3A0c%3A0d%3A0e%3A0f%20--cipher_iv%2000%3A01%3A02%3A03%3A04%3A05%3A06%3A07%3A08%3A09%3A0a%3A0b%3A0c%3A0d%3A0e%3A0f%20--no-mac-updating%3CBR%20%2F%3E%20EAL%EF%BC%9A%E6%A3%80%E6%B5%8B%E5%88%B0%204%20%E4%B8%AA%20lcore%3CBR%20%2F%3E%20EAL%EF%BC%9A%E6%A3%80%E6%B5%8B%E5%88%B0%201%20%E4%B8%AA%20NUMA%20%E8%8A%82%E7%82%B9%3CBR%20%2F%3EEAL%EF%BC%9A%E6%A3%80%E6%B5%8B%E5%88%B0DPDK%E7%9A%84%E9%9D%99%E6%80%81%E9%93%BE%E6%8E%A5%3CBR%20%2F%3EEAL%EF%BC%9A%E6%97%A0%E6%B3%95%E8%A7%A3%E6%9E%90%E8%AE%BE%E5%A4%87%E2%80%9Ccrypto_openssl0%E2%80%9D%3CBR%20%2F%3E%20EAL%EF%BC%9A%E6%97%A0%E6%B3%95%E8%A7%A3%E6%9E%90%E8%AE%BE%E5%A4%87%E2%80%9Ccrypto_openssl0%E2%80%9D%3CBR%20%2F%3E%20EAL%EF%BC%9A%E9%94%99%E8%AF%AF%20-%20%E9%80%80%E5%87%BA%E4%BB%A3%E7%A0%81%EF%BC%9A1%3CBR%20%2F%3E%E5%8E%9F%E5%9B%A0%EF%BC%9AEAL%20%E5%8F%82%E6%95%B0%E6%97%A0%E6%95%88%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSTRONG%3E%E8%AF%B7%E5%B8%AE%E5%8A%A9%E6%88%91%E4%BB%AC%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1857208%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AUbuntu%2020.04%20PC%20%E4%B8%8A%E7%9A%84%20dpdk-l2fwd-crypto%20%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E8%BD%AF%E4%BB%B6%E9%97%AE%E9%A2%98%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1857208%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E9%85%8D%E7%BD%AEPKG_CONFIG_PATH%E5%90%8E%EF%BC%8C%E9%9C%80%E8%A6%81%E4%BD%BF%E7%94%A8%E2%80%9Cmeson%20arm64-build%E2%80%9D%E5%91%BD%E4%BB%A4%E9%87%8D%E6%96%B0%E7%BC%96%E8%AF%91DPDK%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%9C%89%E5%85%B3%E8%AF%A6%E7%BB%86%E4%BF%A1%E6%81%AF%EF%BC%8C%E8%AF%B7%E5%8F%82%E9%98%85%20LSDK%2021.08%20%E7%94%A8%E6%88%B7%E6%89%8B%E5%86%8C%E4%B8%AD%E7%9A%84%E2%80%9C%E4%BD%BF%E7%94%A8%20meson%20%E7%BC%96%E8%AF%91%20DPDK%E2%80%9D%E9%83%A8%E5%88%86%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1857201%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AUbuntu%2020.04%20PC%20%E4%B8%8A%E7%9A%84%20dpdk-l2fwd-crypto%20%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E8%BD%AF%E4%BB%B6%E9%97%AE%E9%A2%98%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1857201%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSTRONG%3E%E6%88%91%E9%81%B5%E5%BE%AA%E7%9A%84%E6%AD%A5%E9%AA%A4%E5%A6%82%E4%B8%8B%EF%BC%9A%3C%2FSTRONG%3E%3CBR%20%2F%3E%20mglocadmin%40mglocadmin-ThinkCentre-M73%3A~%2FNIC%2Fdpdk-21.08%24%E5%AF%BC%E5%87%BA%20PKG_CONFIG_PATH%3D%2Fusr%2Flocal%2Fssl%2Flib%2Fpkgconfig%3A%24PKG_CONFIG_PATH%3C%2FP%3E%3CP%3Emglocadmin%40mglocadmin-ThinkCentre-M73%3A~%2FNIC%2Fdpdk-21.08%24%20cd%20build%2F%3CBR%20%2F%3E%20mglocadmin%40mglocadmin-ThinkCentre-M73%3A~%2FNIC%2Fdpdk-21.08%2Fbuild%24sudo%20ninja%20%E5%AE%89%E8%A3%85%3C%2FP%3E%3CP%3Emglocadmin%40mglocadmin-ThinkCentre-M73%3A~%2FNIC%2Fdpdk-21.08%2Fbuild%24%20cd%20examples%2F%3CBR%20%2F%3E%20mglocadmin%40mglocadmin-ThinkCentre-M73%3A~%2FNIC%2Fdpdk-21.08%2Fbuild%2Fexamples%24sudo%20modprobe%20cryptodev%3CBR%20%2F%3E%20mglocadmin%40mglocadmin-ThinkCentre-M73%3A~%2FNIC%2Fdpdk-21.08%2Fbuild%2Fexamples%24ls%20%2Fdev%2Fcrypto%3CBR%20%2F%3E%20%2Fdev%2Fcrypto%3CBR%20%2F%3E%20mglocadmin%40mglocadmin-ThinkCentre-M73%3A~%2FNIC%2Fdpdk-21.08%2Fbuild%2Fexamples%24openssl%20%E5%BC%95%E6%93%8E%3CBR%20%2F%3E%EF%BC%88rdrand%EF%BC%89%E8%8B%B1%E7%89%B9%E5%B0%94%20RDRAND%20%E5%BC%95%E6%93%8E%3CBR%20%2F%3E%EF%BC%88%E5%8A%A8%E6%80%81%EF%BC%89%E5%8A%A8%E6%80%81%E5%BC%95%E6%93%8E%E5%8A%A0%E8%BD%BD%E6%94%AF%E6%8C%81%3C%2FP%3E%3CP%3Emglocadmin%40mglocadmin-ThinkCentre-M73%3A~%2FNIC%2Fdpdk-21.08%2Fbuild%2Fexamples%24%20sudo%20.%2Fdpdk-l2fwd-crypto-l%201%20-n%202%20--vdev%E2%80%9Ccrypto_openssl0%E2%80%9D--vdev%E2%80%9Ccrypto_openssl1%E2%80%9D---%20-p%200x3%20--chain%20CIPHER_ONLY%20--cdev_type%20SW%20--cipher_algo%20aes-cbc%20--cipher_op%20ENCRYPT%20--cipher_key%2000%3A01%3A02%3A03%3A04%3A05%3A06%3A07%3A08%3A09%3A0a%3A0b%3A0c%3A0d%3A0e%3A0f%20--cipher_iv%2000%3A01%3A02%3A03%3A04%3A05%3A06%3A07%3A08%3A09%3A0a%3A0b%3A0c%3A0d%3A0e%3A0f%20--no-mac-updating%3C%2FP%3E%3CP%3EEAL%EF%BC%9A%E6%A3%80%E6%B5%8B%E5%88%B0%204%20%E4%B8%AA%20lcore%3CBR%20%2F%3E%20EAL%EF%BC%9A%E6%A3%80%E6%B5%8B%E5%88%B0%201%20%E4%B8%AA%20NUMA%20%E8%8A%82%E7%82%B9%3CBR%20%2F%3EEAL%EF%BC%9A%E6%A3%80%E6%B5%8B%E5%88%B0DPDK%E7%9A%84%E9%9D%99%E6%80%81%E9%93%BE%E6%8E%A5%3CBR%20%2F%3EEAL%EF%BC%9A%E6%97%A0%E6%B3%95%E8%A7%A3%E6%9E%90%E8%AE%BE%E5%A4%87%E2%80%9Ccrypto_openssl0%E2%80%9D%3CBR%20%2F%3E%20EAL%EF%BC%9A%E6%97%A0%E6%B3%95%E8%A7%A3%E6%9E%90%E8%AE%BE%E5%A4%87%E2%80%9Ccrypto_openssl0%E2%80%9D%3CBR%20%2F%3E%20EAL%EF%BC%9A%E9%94%99%E8%AF%AF%20-%20%E9%80%80%E5%87%BA%E4%BB%A3%E7%A0%81%EF%BC%9A1%3CBR%20%2F%3E%E5%8E%9F%E5%9B%A0%EF%BC%9AEAL%20%E5%8F%82%E6%95%B0%E6%97%A0%E6%95%88%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E8%BF%98%E6%98%AF%E5%90%8C%E6%A0%B7%E7%9A%84%E9%97%AE%E9%A2%98%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F52411%22%20target%3D%22_blank%22%3E%40yipingwang%3C%2FA%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1857181%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AUbuntu%2020.04%20PC%20%E4%B8%8A%E7%9A%84%20dpdk-l2fwd-crypto%20%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E8%BD%AF%E4%BB%B6%E9%97%AE%E9%A2%98%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1857181%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%AD%A3%E5%A6%82%E6%88%91%E4%B9%8B%E5%89%8D%E6%8F%90%E5%88%B0%E7%9A%84%EF%BC%8C%E8%AF%B7%E5%9C%A8%E6%9E%84%E5%BB%BA%20DPDK%20%E4%B9%8B%E5%89%8D%E6%89%A7%E8%A1%8C%E4%BB%A5%E4%B8%8B%E6%93%8D%E4%BD%9C%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%3Eexport%20PKG_CONFIG_PATH%3D%3COPENSSL%20lib%3D%22%22%20path%3D%22%22%3E%2Flib%2Fpkgconfig%3A%24PKG_CONFIG_PATH%3C%2FOPENSSL%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1856425%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AUbuntu%2020.04%20PC%20%E4%B8%8A%E7%9A%84%20dpdk-l2fwd-crypto%20%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E8%BD%AF%E4%BB%B6%E9%97%AE%E9%A2%98%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1856425%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%B0%A2%E8%B0%A2%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F52411%22%20target%3D%22_blank%22%3E%40yipingwang%3C%2FA%3E%E7%9A%84%E5%9B%9E%E5%A4%8D...%3CBR%20%2F%3E%3CBR%20%2F%3E%E4%BD%86%E6%88%91%E8%AF%95%E5%9B%BE%E5%9C%A8%20PC%20%E4%B8%AD%E6%9E%84%E5%BB%BA%E5%B9%B6%E8%BF%90%E8%A1%8C%20dpdk-l2fwd-crypto%20%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E3%80%82%E6%88%91%E7%9B%B4%E6%8E%A5%E5%AE%89%E8%A3%85%20DPDK%EF%BC%8C%E8%80%8C%E4%B8%8D%E6%98%AF%E4%BD%BF%E7%94%A8%20flex-builder%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%88%91%E6%98%AF%E5%90%A6%E9%9C%80%E8%A6%81%E6%9B%B4%E6%94%B9%E6%88%96%E4%BF%AE%E6%94%B9%20DPDK%20%E4%B8%AD%E7%9A%84%E4%BB%BB%E4%BD%95%E9%85%8D%E7%BD%AE%E4%BB%A5%E5%90%AF%E7%94%A8%20openssl%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1856406%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AUbuntu%2020.04%20PC%20%E4%B8%8A%E7%9A%84%20dpdk-l2fwd-crypto%20%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E8%BD%AF%E4%BB%B6%E9%97%AE%E9%A2%98%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1856406%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%20style%3D%22background%3A%20white%3B%20margin%3A%207.5pt%200cm%200cm%200cm%3B%22%3E%3CSPAN%3E%E6%82%A8%E8%83%BD%E5%90%A6%E6%A3%80%E6%9F%A5%20DPDK%20%E6%98%AF%E5%90%A6%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%E2%80%9Copenssl%E2%80%9D%E5%BA%93%E8%BF%9B%E8%A1%8C%E7%BC%96%E8%AF%91%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22background%3A%20white%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20orphans%3A%202%3B%20widows%3A%202%3B%20-webkit-text-stroke-width%3A%200px%3B%20text-decoration-thickness%3A%20initial%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%20word-spacing%3A%200px%3B%20margin%3A%207.5pt%200cm%200cm%200cm%3B%22%3E%3CSPAN%3E%E4%BD%BF%E7%94%A8%20openssl%20%E7%BC%96%E8%AF%91%20DPDK%20%E5%BF%85%E9%A1%BB%E9%81%B5%E5%BE%AA%E4%BB%A5%E4%B8%8B%E8%B7%AF%E5%BE%84%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22background%3A%20white%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20orphans%3A%202%3B%20widows%3A%202%3B%20-webkit-text-stroke-width%3A%200px%3B%20text-decoration-thickness%3A%20initial%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%20word-spacing%3A%200px%3B%20margin%3A%207.5pt%200cm%200cm%200cm%3B%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22background%3A%20white%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20orphans%3A%202%3B%20widows%3A%202%3B%20-webkit-text-stroke-width%3A%200px%3B%20text-decoration-thickness%3A%20initial%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%20word-spacing%3A%200px%3B%20margin%3A%207.5pt%200cm%200cm%200cm%3B%22%3E%3CSPAN%3Eexport%20PKG_CONFIG_PATH%3D%3COPENSSL%20lib%3D%22%22%20path%3D%22%22%3E%2Flib%2Fpkgconfig%3A%24PKG_CONFIG_PATH%3C%2FOPENSSL%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22background%3A%20white%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20orphans%3A%202%3B%20widows%3A%202%3B%20-webkit-text-stroke-width%3A%200px%3B%20text-decoration-thickness%3A%20initial%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%20word-spacing%3A%200px%3B%20margin%3A%207.5pt%200cm%200cm%200cm%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22background%3A%20white%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20orphans%3A%202%3B%20widows%3A%202%3B%20-webkit-text-stroke-width%3A%200px%3B%20text-decoration-thickness%3A%20initial%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%20word-spacing%3A%200px%3B%20margin%3A%207.5pt%200cm%200cm%200cm%3B%22%3E%3CSPAN%3E%E8%AF%B7%E5%8F%82%E8%80%83%20flexbuild_lsdk2108_github%2Fpackages%2Fapps%2Fnetworking%2Fdpdk.mk%20%E4%B8%AD%E7%9A%84%E4%BB%A5%E4%B8%8B%E8%A1%8C%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22background%3A%20white%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20orphans%3A%202%3B%20widows%3A%202%3B%20-webkit-text-stroke-width%3A%200px%3B%20text-decoration-thickness%3A%20initial%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%20word-spacing%3A%200px%3B%20margin%3A%207.5pt%200cm%200cm%200cm%3B%22%3E%3CSPAN%3E%3CCODE%20data-application%3D%22com.atlassian.bitbucket-server%22%20data-language%3D%22plain%20text%22%3Eexport%20PKG_CONFIG_PATH%3D%24(DESTDIR)%2Fusr%2Flocal%2Flib%2Fpkgconfig%3A%24(PKG_CONFIG_PATH)%20%26amp%3B%26amp%3B%20%5C%3C%2FCODE%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
