According to https://community.nxp.com/t5/S32-Design-Studio-Knowledge-Base/HOWTO-Use-IVT-Tool-To-Create-A-Blob-Im..., i download image to flash, and it's successful.
But, i download again, and it failed.
And, i use S32 Flash Tool to try, and it failed as well.
S32 Debug Probe don't debug too.
What should I do to make it ok?
PS: The EVB state is as follows, is the state of blue led ok?
Solved! Go to Solution.
regarding Blue LED D9:
and from datasheet:
So you have active reset when D9 is on.
Peter
and from datasheet:
Peter
Hi Peter,
I got it.
I have set EVB to boot from SD card, and erase flash by "flash_erase" command in linux system.
Thank you very much for your help.
