Dealing with Thermal Pad of PCAL6524HEAZ
434件の閲覧回数
Edgard
Dear an Engineer in NXP
I have one question about the Thermal Pad of PCAL6524HEAZ.
I checked the comment that the Thermal Pad is not connected to internal chip directly.
Is it NOT necessary to connect to GND pattern on PCB with the Thermal Pad?
Thanks in advance
Edgard
408件の閲覧回数
JozefKozon
Dear Eduard,
you are correct. The thermal pad underneath the PCAL6524HEAZ is not internally connected to any pin. It can be left floating, but for better thermal performance it is recommended to connect it to the GND.
With Best Regards,
Jozef
2 返答(返信)
409件の閲覧回数
JozefKozon
Dear Eduard,
With Best Regards,
Jozef
404件の閲覧回数
Edgard
Dear Jozef
thanks for your quick response.
I may connect the Thermal PAD to GND.
Kindest Regards
Edgard
