It looks like from the video sent that you are receiving error $0000001B. This error means that the SAP image you have created requires a higher firmware version on the Cyclone Pro. To update the Cyclone Pro firmware, download and install the latest Cyclone Legacy Programmer Installation Software.
From PEmicro’s website - navigate to the Support Page and then to Documentation and Downloads. In the Download Type section click the “Software Update” link. The software you will want is the “Cyclone Legacy Programmer Installation Software”.
After installing this software, run any application in PEmicro Cyclone Legacy to connect to the Cyclone Pro and it will update the Cyclone Pro firmware from 8.53-1.6 to 8.82-1.6. Try your process again and you should no longer see error $0000001B. Hope this helps!
Steve
Can you please confirm that you have a correct connection between the cyclone and your board, I only see 3 wires, is this correct?
the cyclone is supplying the power to your board?
The program on the cyclone is for the PL device?
Please let me know your comments
Google Translate
CYCLONE PRO When burning the MC9S08PL16 series chip, due to the failure of burning, the burner was upgraded from 1.53-1.6 to 8.69-1.6 by the burner. The SAP file was burned and found, Erase, lamp, Verify light is not on, please Help analyze the reasons, thank you!
