Boot the lx2160ardb_rev2 in sdcard mode
297 次查看
Jayalakshmi24
My task is to boot the lx2160ardb_rev2 in sd card mode and to create partition with the binaries.How to disable other .dtb except lx2160ardb_rev2 from the generated boot_LS_arm64_lts_5.10_202405091415.tgz?
245 次查看
LFGP
Actually is not possible to generate only one .dtb file as you want
237 次查看
Jayalakshmi24
Thanks for the reply. I need only dtb files which is related to lx2160ardb_rev2.
221 次查看
LFGP
please run the next command in order to get the dbt file among other needed file, the command will generate a tarball,
$ bitbake generate-boottgz
review into the LLDP user manual the chapter "3.5.6 Generate tarball"
