Black screen issue in RT1170-EVK board with RASPI-7INCH screen using GUI-GUIDER
868 次查看
AdiSharonOBTools
I am trying to see a Lottie animation in my screen, but experiencing black screen.
I am Using Gui Guider 1.7.2
MCUXpresso 11.9
sdk 2.15
RT1170-EVK board
RASPI-7INCH screen
Here is a video of my process:
https://www.loom.com/share/38901eb621644003b9dff977a03a4c48?sid=369050dc-d06a-4186-befd-d8bfea334c48
I would really appreciate your advice- what could cause the black screen issue?
Adi
9 回复数
846 次查看
EdwinHz
Hi @AdiSharonOBTools,
This seems to be an issue with the LCD screen, rather than the project. You see a black screen because the application seems to get stuck under the "MIPI_DSI_MemoryDoneDriverCallback()". What LCD are you using? Have you tried using other LCDs? Has this LCD worked before?
BR,
Edwin.
802 次查看
AdiSharonOBTools
Hi @EdwinHz
I am using a Raspberry Pi Touch Screen 7″ 800×480.
I didn't try a differtent LCD.
I did succeed to run one project with one Lottie animation, but can't reproduce it with other Lottie files.
Adi
766 次查看
EdwinHz
Are you seeing the same issue when running the application from GUI Guider?
BR,
Edwin.
711 次查看
AdiSharonOBTools
Yes.
I've never succeeded to run simulator from GUI Guider on my screen.
I always get an error, even with projects that run perfectly on MCUXpresso.
Here is a sample log I get when try to running simulator from GUI Guider on my screen:
Cleaning Generate screen files......
Generate C Code
Copying Generate Code
Run Cmake To Generate Makefile
-- TOOLCHAIN_DIR: C:/nxp/MCUXpressoIDE_11.9.0_2144/ide/tools -- BUILD_TYPE: flexspi_nor_sdram_release -- TOOLCHAIN_DIR: C:/nxp/MCUXpressoIDE_11.9.0_2144/ide/tools -- BUILD_TYPE: flexspi_nor_sdram_release -- The ASM compiler identification is GNU -- Found assembler: C:/nxp/MCUXpressoIDE_11.9.0_2144/ide/tools/bin/arm-none-eabi-gcc.exe -- The C compiler identification is GNU 12.3.1 -- The CXX compiler identification is GNU 12.3.1 C:/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/CMSIS/CMSIS_Include_core_cm.cmake component is included. C:/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/component/lists/component_lists.MIMXRT1176.cmake component is included. C:/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/video/driver_dc-fb-elcdif.MIMXRT1176.cmake component is included. C:/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/drivers/driver_soc_mipi_dsi.MIMXRT1176.cmake component is included. C:/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/freertos/freertos-kernel/middleware_freertos-kernel_template.cmake component is included. C:/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/vglite/middleware_vglite.cmake component is included. -- Configuring done -- Generating done -- Build files have been written to: C:/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/armgcc/build
Build Flash Image
Scanning dependencies of target lvgl_guider_cm7.elf [ 0%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/board/board.c.obj [ 0%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/board/clock_config.c.obj [ 1%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/board/dcd.c.obj [ 1%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/board/display_support.c.obj [ 1%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/board/lvgl_support.c.obj [ 2%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/board/pin_mux.c.obj [ 2%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/board/vglite_support.c.obj [ 2%] Building CXX object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/source/h264_dec.cpp.obj [ 3%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/source/lvgl_demo_utils.c.obj [ 3%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/source/lvgl_freertos.c.obj [ 3%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/source/lvgl_guider.c.obj [ 4%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/source/pca6416.c.obj [ 4%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/source/rpi.c.obj [ 4%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/custom/custom.c.obj [ 5%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/generated/events_init.c.obj [ 5%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/generated/gui_guider.c.obj [ 5%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/generated/images/lottie_bear.c.obj [ 6%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/generated/setup_scr_screen.c.obj [ 6%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/generated/widgets_init.c.obj [ 6%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/component/lists/fsl_component_generic_list.c.obj [ 7%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/component/uart/fsl_adapter_lpuart.c.obj [ 7%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/component/serial_manager/fsl_component_serial_manager.c.obj [ 7%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/component/serial_manager/fsl_component_serial_port_uart.c.obj [ 8%] Building ASM object CMakeFiles/lvgl_guider_cm7.elf.dir/startup/startup_MIMXRT1176_cm7.S.obj [ 8%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/device/system_MIMXRT1176_cm7.c.obj [ 8%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/drivers/fsl_anatop_ai.c.obj [ 9%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/drivers/fsl_cache.c.obj [ 9%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/drivers/fsl_clock.c.obj [ 9%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/drivers/fsl_common.c.obj [ 10%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/drivers/fsl_common_arm.c.obj [ 10%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/video/fsl_dc_fb_elcdif.c.obj [ 10%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/video/fsl_dc_fb_lcdifv2.c.obj [ 11%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/drivers/fsl_dcdc.c.obj [ 11%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/video/fsl_hx8394.c.obj [ 12%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/video/fsl_mipi_dsi_cmd.c.obj [ 12%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/video/fsl_rm68191.c.obj [ 12%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/video/fsl_rm68200.c.obj [ 13%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/drivers/fsl_elcdif.c.obj [ 13%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/touchpanel/fsl_ft5406_rt.c.obj [ 13%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/drivers/fsl_gpc.c.obj [ 14%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/touchpanel/fsl_gt911.c.obj [ 14%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/drivers/fsl_gpio.c.obj [ 14%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/drivers/fsl_lcdifv2.c.obj [ 15%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/drivers/fsl_lpi2c.c.obj [ 15%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/drivers/fsl_lpuart.c.obj [ 15%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/drivers/fsl_mipi_dsi.c.obj [ 16%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/drivers/fsl_mu.c.obj [ 16%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/drivers/fsl_pmu.c.obj [ 16%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/drivers/fsl_pxp.c.obj [ 17%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/drivers/fsl_soc_mipi_csi2rx.c.obj [ 17%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/drivers/fsl_soc_src.c.obj [ 17%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/video/fsl_video_common.c.obj [ 18%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/xip/evkbmimxrt1170_flexspi_nor_config.c.obj [ 18%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/xip/fsl_flexspi_nor_boot.c.obj [ 18%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/board/xmcd.c.obj [ 19%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/freertos/freertos-kernel/croutine.c.obj [ 19%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/freertos/freertos-kernel/event_groups.c.obj [ 19%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/freertos/freertos-kernel/list.c.obj [ 20%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/freertos/freertos-kernel/queue.c.obj [ 20%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/freertos/freertos-kernel/stream_buffer.c.obj [ 20%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/freertos/freertos-kernel/tasks.c.obj [ 21%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/freertos/freertos-kernel/timers.c.obj [ 21%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/freertos/freertos-kernel/portable/GCC/ARM_CM4F/port.c.obj [ 21%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/freertos/freertos-kernel/portable/MemMang/heap_4.c.obj [ 22%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/core/lv_disp.c.obj [ 22%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/core/lv_event.c.obj [ 23%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/core/lv_group.c.obj [ 23%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/core/lv_indev.c.obj [ 23%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/core/lv_indev_scroll.c.obj [ 24%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/core/lv_obj.c.obj [ 24%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/core/lv_obj_class.c.obj [ 24%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/core/lv_obj_draw.c.obj [ 25%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/core/lv_obj_pos.c.obj [ 25%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/core/lv_obj_scroll.c.obj [ 25%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/core/lv_obj_style.c.obj [ 26%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/core/lv_obj_style_gen.c.obj [ 26%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/core/lv_obj_tree.c.obj [ 26%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/core/lv_refr.c.obj [ 27%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/core/lv_theme.c.obj [ 27%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/draw/lv_draw.c.obj [ 27%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/draw/lv_draw_layer.c.obj [ 28%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/draw/lv_draw_transform.c.obj [ 28%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/draw/lv_draw_arc.c.obj [ 28%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/draw/lv_draw_img.c.obj [ 29%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/draw/lv_draw_label.c.obj [ 29%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/draw/lv_draw_line.c.obj [ 29%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/draw/lv_draw_mask.c.obj [ 30%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/draw/lv_draw_rect.c.obj [ 30%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/draw/lv_draw_triangle.c.obj [ 30%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/draw/lv_img_buf.c.obj [ 31%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/draw/lv_img_cache.c.obj [ 31%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/draw/lv_img_decoder.c.obj [ 31%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/draw/nxp/pxp/lv_draw_pxp.c.obj [ 32%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/draw/nxp/pxp/lv_draw_pxp_blend.c.obj [ 32%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/draw/nxp/pxp/lv_gpu_nxp_pxp.c.obj [ 32%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/draw/nxp/pxp/lv_gpu_nxp_pxp_osa.c.obj [ 33%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/draw/nxp/vglite/lv_draw_vglite.c.obj [ 33%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/draw/nxp/vglite/lv_draw_vglite_blend.c.obj [ 34%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/draw/nxp/vglite/lv_draw_vglite_rect.c.obj [ 34%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/draw/nxp/vglite/lv_draw_vglite_line.c.obj [ 34%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/draw/nxp/vglite/lv_draw_vglite_arc.c.obj [ 35%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/draw/nxp/vglite/lv_vglite_buf.c.obj [ 35%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/draw/nxp/vglite/lv_vglite_utils.c.obj [ 35%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/draw/sdl/lv_draw_sdl.c.obj [ 36%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/draw/sdl/lv_draw_sdl_arc.c.obj [ 36%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/draw/sdl/lv_draw_sdl_bg.c.obj [ 36%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/draw/sdl/lv_draw_sdl_composite.c.obj [ 37%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/draw/sdl/lv_draw_sdl_img.c.obj [ 37%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/draw/sdl/lv_draw_sdl_label.c.obj [ 37%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/draw/sdl/lv_draw_sdl_mask.c.obj [ 38%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/draw/sdl/lv_draw_sdl_polygon.c.obj [ 38%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/draw/sdl/lv_draw_sdl_rect.c.obj [ 38%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/draw/sdl/lv_draw_sdl_stack_blur.c.obj [ 39%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/draw/sdl/lv_draw_sdl_texture_cache.c.obj [ 39%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/draw/sdl/lv_draw_sdl_utils.c.obj [ 39%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/draw/sdl/lv_draw_sdl_line.c.obj [ 40%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/draw/sdl/lv_draw_sdl_layer.c.obj [ 40%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/draw/stm32_dma2d/lv_gpu_stm32_dma2d.c.obj [ 40%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/draw/renesas/lv_gpu_d2_ra6m3.c.obj [ 41%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/draw/renesas/lv_gpu_d2_draw_label.c.obj [ 41%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/draw/sw/lv_draw_sw.c.obj [ 41%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/draw/sw/lv_draw_sw_arc.c.obj [ 42%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/draw/sw/lv_draw_sw_blend.c.obj [ 42%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/draw/sw/lv_draw_sw_dither.c.obj [ 42%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/draw/sw/lv_draw_sw_gradient.c.obj [ 43%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/draw/sw/lv_draw_sw_img.c.obj [ 43%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/draw/sw/lv_draw_sw_letter.c.obj [ 43%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/draw/sw/lv_draw_sw_line.c.obj [ 44%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/draw/sw/lv_draw_sw_polygon.c.obj [ 44%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/draw/sw/lv_draw_sw_rect.c.obj [ 45%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/draw/sw/lv_draw_sw_transform.c.obj [ 45%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/draw/sw/lv_draw_sw_layer.c.obj [ 45%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/font/lv_font.c.obj [ 46%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/font/lv_font_dejavu_16_persian_hebrew.c.obj [ 46%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/font/lv_font_fmt_txt.c.obj [ 46%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/font/lv_font_loader.c.obj [ 47%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/font/lv_font_montserrat_10.c.obj [ 47%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/font/lv_font_montserrat_12.c.obj [ 47%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/font/lv_font_montserrat_12_subpx.c.obj [ 48%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/font/lv_font_montserrat_14.c.obj [ 48%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/font/lv_font_montserrat_16.c.obj [ 48%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/font/lv_font_montserrat_18.c.obj [ 49%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/font/lv_font_montserrat_20.c.obj [ 49%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/font/lv_font_montserrat_22.c.obj [ 49%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/font/lv_font_montserrat_24.c.obj [ 50%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/font/lv_font_montserrat_26.c.obj [ 50%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/font/lv_font_montserrat_28.c.obj [ 50%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/font/lv_font_montserrat_28_compressed.c.obj [ 51%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/font/lv_font_montserrat_30.c.obj [ 51%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/font/lv_font_montserrat_32.c.obj [ 51%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/font/lv_font_montserrat_34.c.obj [ 52%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/font/lv_font_montserrat_36.c.obj [ 52%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/font/lv_font_montserrat_38.c.obj [ 52%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/font/lv_font_montserrat_40.c.obj [ 53%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/font/lv_font_montserrat_42.c.obj [ 53%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/font/lv_font_montserrat_44.c.obj [ 53%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/font/lv_font_montserrat_46.c.obj [ 54%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/font/lv_font_montserrat_48.c.obj [ 54%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/font/lv_font_montserrat_8.c.obj [ 54%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/font/lv_font_simsun_16_cjk.c.obj [ 55%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/font/lv_font_unscii_16.c.obj [ 55%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/font/lv_font_unscii_8.c.obj [ 56%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/hal/lv_hal_disp.c.obj [ 56%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/hal/lv_hal_indev.c.obj [ 56%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/hal/lv_hal_tick.c.obj [ 57%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/misc/lv_anim.c.obj [ 57%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/misc/lv_anim_timeline.c.obj [ 57%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/misc/lv_area.c.obj [ 58%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/misc/lv_async.c.obj [ 58%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/misc/lv_bidi.c.obj [ 58%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/misc/lv_color.c.obj [ 59%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/misc/lv_fs.c.obj [ 59%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/misc/lv_gc.c.obj [ 59%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/misc/lv_ll.c.obj [ 60%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/misc/lv_log.c.obj [ 60%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/misc/lv_math.c.obj [ 60%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/misc/lv_mem.c.obj [ 61%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/misc/lv_printf.c.obj [ 61%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/misc/lv_style.c.obj [ 61%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/misc/lv_style_gen.c.obj [ 62%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/misc/lv_templ.c.obj [ 62%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/misc/lv_timer.c.obj [ 62%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/misc/lv_tlsf.c.obj [ 63%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/misc/lv_txt_ap.c.obj [ 63%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/misc/lv_txt.c.obj [ 63%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/misc/lv_utils.c.obj [ 64%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/misc/lv_lru.c.obj [ 64%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/widgets/lv_arc.c.obj [ 64%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/widgets/lv_bar.c.obj [ 65%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/widgets/lv_btn.c.obj [ 65%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/widgets/lv_btnmatrix.c.obj [ 65%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/widgets/lv_canvas.c.obj [ 66%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/widgets/lv_checkbox.c.obj [ 66%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/widgets/lv_dropdown.c.obj [ 67%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/widgets/lv_img.c.obj [ 67%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/widgets/lv_label.c.obj [ 67%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/widgets/lv_line.c.obj [ 68%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/widgets/lv_objx_templ.c.obj [ 68%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/widgets/lv_roller.c.obj [ 68%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/widgets/lv_slider.c.obj [ 69%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/widgets/lv_switch.c.obj [ 69%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/widgets/lv_table.c.obj [ 69%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/widgets/lv_textarea.c.obj [ 70%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/extra/layouts/flex/lv_flex.c.obj [ 70%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/extra/layouts/grid/lv_grid.c.obj [ 70%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/extra/libs/barcode/code128.c.obj [ 71%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/extra/libs/barcode/lv_barcode.c.obj [ 71%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/extra/libs/bmp/lv_bmp.c.obj [ 71%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/extra/libs/freetype/lv_freetype.c.obj [ 72%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/extra/libs/fsdrv/lv_fs_fatfs.c.obj [ 72%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/extra/libs/fsdrv/lv_fs_posix.c.obj [ 72%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/extra/libs/fsdrv/lv_fs_rawfs.c.obj [ 73%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/extra/libs/fsdrv/lv_fs_stdio.c.obj [ 73%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/extra/libs/fsdrv/lv_fs_win32.c.obj [ 73%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/extra/libs/gif/gifdec.c.obj [ 74%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/extra/libs/gif/lv_gif.c.obj [ 74%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/extra/libs/png/lodepng.c.obj [ 74%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/extra/libs/png/lv_png.c.obj [ 75%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/extra/libs/qrcode/lv_qrcode.c.obj [ 75%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/extra/libs/qrcode/qrcodegen.c.obj [ 75%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/extra/libs/rlottie/lv_rlottie.c.obj [ 76%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/extra/libs/sjpg/lv_sjpg.c.obj [ 76%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/extra/libs/sjpg/tjpgd.c.obj [ 76%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/extra/libs/ffmpeg/lv_ffmpeg.c.obj [ 77%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/extra/lv_extra.c.obj [ 77%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/extra/others/snapshot/lv_snapshot.c.obj [ 78%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/extra/others/gridnav/lv_gridnav.c.obj [ 78%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/extra/others/monkey/lv_monkey.c.obj [ 78%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/extra/others/fragment/lv_fragment.c.obj [ 79%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/extra/others/fragment/lv_fragment_manager.c.obj [ 79%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/extra/others/ime/lv_ime_pinyin.c.obj [ 79%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/extra/others/imgfont/lv_imgfont.c.obj [ 80%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/extra/others/msg/lv_msg.c.obj [ 80%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/extra/themes/basic/lv_theme_basic.c.obj [ 80%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/extra/themes/default/lv_theme_default.c.obj [ 81%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/extra/themes/mono/lv_theme_mono.c.obj [ 81%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/extra/widgets/analogclock/lv_analogclock.c.obj [ 81%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/extra/widgets/animimg/lv_animimg.c.obj [ 82%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/extra/widgets/calendar/lv_calendar.c.obj [ 82%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/extra/widgets/calendar/lv_calendar_header_arrow.c.obj [ 82%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/extra/widgets/calendar/lv_calendar_header_dropdown.c.obj [ 83%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/extra/widgets/carousel/lv_carousel.c.obj [ 83%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/extra/widgets/chart/lv_chart.c.obj [ 83%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/extra/widgets/colorwheel/lv_colorwheel.c.obj [ 84%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/extra/widgets/dclock/lv_dclock.c.obj [ 84%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/extra/widgets/imgbtn/lv_imgbtn.c.obj [ 84%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/extra/widgets/keyboard/lv_keyboard.c.obj [ 85%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/extra/widgets/keyboard/lv_zh_keyboard.c.obj [ 85%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/extra/widgets/led/lv_led.c.obj [ 85%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/extra/widgets/list/lv_list.c.obj [ 86%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/extra/widgets/meter/lv_meter.c.obj [ 86%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/extra/widgets/msgbox/lv_msgbox.c.obj [ 86%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/extra/widgets/radiobtn/lv_radiobtn.c.obj [ 87%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/extra/widgets/span/lv_span.c.obj [ 87%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/extra/widgets/spinbox/lv_spinbox.c.obj [ 87%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/extra/widgets/spinner/lv_spinner.c.obj [ 88%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/extra/widgets/tabview/lv_tabview.c.obj [ 88%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/extra/widgets/textprogress/lv_textprogress.c.obj [ 89%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/extra/widgets/tileview/lv_tileview.c.obj [ 89%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/extra/widgets/video/lv_video.c.obj [ 89%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/extra/widgets/win/lv_win.c.obj [ 90%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/lvgl/lvgl/src/extra/widgets/menu/lv_menu.c.obj [ 90%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/vglite/VGLite/vg_lite.c.obj [ 90%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/vglite/VGLite/vg_lite_image.c.obj [ 91%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/vglite/VGLite/vg_lite_matrix.c.obj [ 91%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/vglite/VGLite/vg_lite_path.c.obj [ 91%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/vglite/VGLite/nxp_support.c.obj [ 92%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/vglite/VGLite/vg_lite_flat.c.obj [ 92%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/vglite/VGLite/rtos/vg_lite_os.c.obj [ 92%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/vglite/font/buf_reader.c.obj [ 93%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/vglite/font/rle_font_read.c.obj [ 93%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/vglite/font/vft_debug.c.obj [ 93%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/vglite/font/vft_draw.c.obj [ 94%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/vglite/font/vg_lite_text.c.obj [ 94%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/vglite/font/mcufont/decoder/mf_bwfont.c.obj [ 94%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/vglite/font/mcufont/decoder/mf_encoding.c.obj [ 95%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/vglite/font/mcufont/decoder/mf_font.c.obj [ 95%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/vglite/font/mcufont/decoder/mf_justify.c.obj [ 95%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/vglite/font/mcufont/decoder/mf_kerning.c.obj [ 96%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/vglite/font/mcufont/decoder/mf_rlefont.c.obj [ 96%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/vglite/font/mcufont/decoder/mf_scaledfont.c.obj [ 96%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/vglite/font/mcufont/decoder/mf_wordwrap.c.obj [ 97%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/vglite/VGLiteKernel/vg_lite_kernel.c.obj [ 97%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/vglite/VGLiteKernel/rtos/vg_lite_hal.c.obj [ 97%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/utilities/fsl_sbrk.c.obj [ 98%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/utilities/fsl_syscall_stub.c.obj [ 98%] Building ASM object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/utilities/fsl_memcpy.S.obj [ 98%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/utilities/fsl_assert.c.obj [ 99%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/utilities/fsl_str.c.obj [ 99%] Building C object CMakeFiles/lvgl_guider_cm7.elf.dir/C_/nxp/GUI-Guider-Projects/Bear_evkb_h/sdk/Core/utilities/fsl_debug_console.c.obj [100%] Linking CXX executable lvgl_guider_cm7.elf Memory region Used Size Region Size %age Used m_flash_config: 512 B 3 KB 16.67% m_ivt: 32 B 32 B 100.00% m_boot_data: 16 B 16 B 100.00% m_dcd_data: 0 GB 1768 B 0.00% m_xmcd_data: 16 B 516 B 3.10% m_interrupts: 1 KB 1 KB 100.00% m_text: 710020 B 65271 KB 1.06% m_qacode: 0 GB 256 KB 0.00% m_data: 4934032 B 48640 KB 9.91% m_data2: 0 GB 256 KB 0.00% m_data3: 0 GB 512 KB 0.00% m_ncache: 32 B 16 MB 0.00% m_heap: 512 KB 512 KB 100.00% [100%] Built target lvgl_guider_cm7.elf Ns: MCUXpresso IDE RedlinkMulti Driver v11.9 (Nov 15 2023 11:19:30 - crt_emu_cm_redlink build 621) Nc: Reconnected to existing LinkServer process. Nc: Connecting to probe 0 core 0 (using server started externally) reports: 'Ee(42). Could not connect to core.' Nc: Retrying... Nc: Reconnected to existing LinkServer process. Nc: Server OK but no connection to probe 0 core -2(ANY) (after 3 attempts) - Ee(42). Could not connect to core. Ed:02: Failed on connect: Ee(42). Could not connect to core. Et:31: No connection to chip's debug port
695 次查看
EdwinHz
Can you confirm that the board is not in Serial Downloader mode? This might be the cause of why the application can run in MCUXpresso but not GUI Guider.
BR,
Edwin.
672 次查看
AdiSharonOBTools
Hi @EdwinHz
Indeed, I confirm that the board is not in Serial Downloader mode.
See attached photo.
Can you provide me a link or explanation step by step on how to create a simple GUI Guider project and run it on MCUXpresso?
I want to verify that the steps I'm doing (as you can see in the video) are correct.
Adi
623 次查看
EdwinHz
I attach the requested video sample of how to import a GUI Guider project to MCUXpresso.
BR,
Edwin.
612 次查看
AdiSharonOBTools
Thanks for the video.
I did the same so still not sure why I get black screen.
602 次查看
EdwinHz
Please debug you project in MCUXpresso step by step and let me know in what part of the application the execution gets halted. This will be very helpful in order to pinpoint the issue and how to proceed with a possible solution.
BR,
Edwin.
