Dear NXP tech experts,
Currently I am supporting ctm radar project, (S32R418, SAF8544), is there software reuse documents about S32R, SAF85xx, which maybe list which software or component are common for S32R, SAF8544, something like common IDE, SAF, SPD, IPCF, protocols stack(TCP/IP, CAN ), and which software component are different. thanks for your help!
Not sure if I understood you correctly.
But, S32 devices has common IDE. You can use S32 Design studio or any third party which support these devices.
SAF, SPD, RTD - those will be unique for each S32 device. As they implement different memories, IPs, etc...
Peter
