hi nxp tec support teams, my main board base udx710, connect AW-XM458 wifi module by pcie2.0, my issue can't detected wifi device by commond 'lspci'
Hello @huangcm
1. Which module you use? As I know, AW-XM458 only have M.2 module supports pcie. If you use M,2 interface, you should check whether host side enable M.2 pcie.
2. Please try load driver, if card is detected, fw will download successfully.
3. Please check IO level and clock.
Best Regards
Shaun
