My project don't use buck1&buck2.
I find how to use MC33FS8430G1ES with out buck1 in AN12333,but not find how to use MC33FS8430G1ES with out buck2. Is it same?
Solved! Go to Solution.
Hello Jing,
We suggest to keep the LDO1 related pins connected just like the enabled LDO1. And you can just do not use the LDO1 output .
You can disable the LDO1 output after power up by below bit if you want.
Anything unclear , please let me know.
David
Hello Jing,
I hope all is great with you.
You are correct, the same procedure can be applied to the BUCK2 regulator in case both regulators are not used.
David
Thanks a lot~ How about LDO1?
Hello Jing,
David
I was just checking.There's not muck room on the board.
Can LDO1 be suspended directly?
Could you check the circuit diagram for me?
