USBDM_JMXXCLD
USBDM_JMXXCLD
1,014 次查看
somy
Dear all,
I am new to OSBDM, I have purchased one USBDM_JMXXCLD and using it, it worked for two days, now pc is unable to recognise it, i have tried on different PCs, I have checked the power supply on controller pins it is ok, what may be the reason?
sanjay
380 次查看
pgo
Senior Contributor V
Hi Sanjay,
If it was working and now is not working it would seem most likely to be a hardware or mechanical problem with the BDM rather than a software one.  Especially if it doesn't work on other PCs.
For what it's worth you can try installing the latest drivers (not the applications) from Sourceforge as they seem a bit more reliable at installing but I would think it unlikely that it will make any change.
As you have only used the BDM for a few days I would suggest contacting the seller as it may be defective.
I have had no trouble with reliability except if used incorrectly e.g. excessive target power etc,
bye
