Dear Forum users,
i tried to use TBDML debugger for S12XF processors but had no luck.
In Codewarrior IDE when i choose e.g. MC9S12XF512 CPU, the TBDML debugger availabilty in the configuration window disappears. Can anybody explain to me why S12XF familiy is not supported by TBDML? Is there a technical matter? Did anybody had success with debugging S12XF? How?
Thanks in advance,
Gregor
Dear gregor,
TBDML is getting to be pretty old and hasn't had been updated for a while so it's not unreasonable for it not to be supported for new targets.
Haven't tried the XF chip but if you want to be adventurous you can try the following:
There might also be problems with the speed of the target as TBDML is quite limited.
bye
