Hi, friends, how are you? i have a question, anybody have a manual about how to use BDM? how can i make the first program and load it. if a use the TBDML interface.
first:F7,make the project,then F5 debug the project ,in the command window put in'set gdi',Ctrl+R reset the mcu,at the top in the tbdm window flash,here first you erase the program in the flash ,then you can load your file into the flasg
