ARM_Programmer specify programmer
1,157件の閲覧回数
matthewharper
I was looking at the command line options for the ARM_Programmer.exe utility and noticed there is no option to specify the programmer.  You can specify a programmer in GUI via the drop down.
It's potentially important because I have 'gang of four' situation, programming 4 boards at a time.
Also was looking into building the code via msys.  I'm assuming everything is built under msys? x Except the documentation?  Related to that I noticed on the web page you say
Run the command CollectExternalFiles.  This appears commented out. Should I use Collect Shared files instead?
Thx
816件の閲覧回数
pgo
Senior Contributor V
Hi Matthew,
I have just added the option to select a programmer.  It will be available in the next version.
CollectExternalFiles  Collects external files from the different application locations e.g. wxWidgets DLLs etc to a staging location. This is to allow me to check what has changed.  The only reason it is disabled is so I don't accidentally do it.  I only run it when I change some contributing software version and then check the result.
CollectSharedFiles Copies from the staging location into where they are used by a build.
The above is just me being careful to not accidentally change something.
bye
5 返答(返信)
817件の閲覧回数
pgo
Hi Matthew,
bye
816件の閲覧回数
matthewharper
Another little thing CleanAll was failing because
USBDM_API_Example\Target.mk includes USBDM_API_Example\Common.mk instead of ../Common.mk.
I has to adjust the paths in USBDM_API_Example\Common.mk to point to mingw32-make.exe
816件の閲覧回数
matthewharper
Also another crap out on compiling.
-- Linking Target UsbdmScript/UsbdmScript.exe
c:/MinGW/bin/gcc -o UsbdmScript/UsbdmScript.exe  -s -mthreads  UsbdmScript/DSC_U
tilities.o UsbdmScript/Names.o UsbdmScript/usbdmTcl.o UsbdmScript/FindWindow.o U
sbdmScript/Version.o  -L../Shared_V4/lib -L../PackageFiles/bin/win32  -lusbdm.4
  -lusbdm-dsc.4  -ltcl85 -lwxmsw30u_core_gcc_custom -lwxbase30u_gcc_custom -lwxm
sw30u_adv_gcc_custom         -lusbdm-wxPlugin
UsbdmScript/usbdmTcl.o:usbdmTcl.c:(.text.startup+0x2f): undefined reference to `
_imp__Tcl_MainEx'
collect2.exe: error: ld returned 1 exit status
Target.mk:91: recipe for target 'UsbdmScript/UsbdmScript.exe' failed
mingw32-make[2]: *** [UsbdmScript/UsbdmScript.exe] Error 1
mingw32-make[2]: Leaving directory 'c:/projects/USBDMProgect/build/usbdm-eclipse
-makefiles-build-master/Usbdm_TCL'
Makefile:15: recipe for target 'UsbdmScript' failed
mingw32-make[1]: *** [UsbdmScript] Error 2
mingw32-make[1]: Leaving directory 'c:/projects/USBDMProgect/build/usbdm-eclipse
make: *** [build-Usbdm_TCL] Error 2
One thing I note is, you link I think against tcl85.dll but the latest 'free' download for tcl is tcl86.  Wondering if that is the problem?
816件の閲覧回数
matthewharper
_imp__Tcl_MainEx'
Fixed this by uninstalling the 64 bit version of tcl86. Installing the 32 bit version and updating Common.mk to link to tcl86.dll instead of tcl85.dll
816件の閲覧回数
matthewharper
That will make me very happy!!!!!
So I was digging trying to get this to compile. I ran into a problem failed on not being able to find SHCreateDirectoryEx()
I traced that down I thin to this like in Log.cpp
#ifdef WIN32
#define _WIN32_IE 0x0500      //!< Required for later system calls.
//#define _WIN32_WINNT 0x0500   //!< Required for later system calls.
#include <shlobj.h>
_WIN32_WINNT 0x0500 being commented out means that SHCreateDirectoryEx() isn't defined in shlobj.h
