Is there any command line simulator available for S32K14x controllers, like sim30 for PIC.
I just want to configure ceedling to run the test on the simulator.
Hi rajuparammal,
As far as i know NXP does not have a simulator for the S32K14x product families capable to simulate the core and peripherals.
Nonetheless, if you wish to test some generic C code on an ARM core similar with the one used by S32K14x controllers then i would suggest to look at IAR Workbench IDE. They support various ARM core simulators and depending on the code size of your project you might be able to use it for free.
Hope it helps!
Thanks. I have no plans to go with IAR Workbench. Is there any good open source simulator for arm Cortex M4?
Hi rajuparammal,
Perhaps you can have a look at QEMU: The GNU MCU Eclipse QEMU
Based on their release notes you should expect some limitations but it should cover for most of what you wish for.
Hi Daniel,
Nice to know about the QEMU.
I actually had RAM issues & would like to replicate the same on QEMU.
Kindly confirm whether QEMU supports RAM simulator as well.
Thanks in advance,
Raju.
