RDSTEPPER56F84789: Micro-Step Stepper Motor Control Solution
Overview
This reference design is based on 32-bit DSC MC56F84789, to demo a micro-step stepper motor control solution. This reference design jump-starts your ability to leverage the NXP® DSCs' advanced feature sets via complete software, tools and hardware platform.
  • Two phases four wires stepper motor
  • Motor self-adaptive function, auto motor parameters identification and control system adjustment
  • Rated peak current selection by switch, the maximum current is up to 8 A
  • Speed ratio: 1 : 1000 with position and speed closed loop control
  • Current PID regulator
  • Micro-step resolution selection by switch, the maximum resolution is up to 25600 steps/rev
  • The maximum speed is up to 3000RPM with loading capability
  • Pulse command mode: single pulse plus direction control
  • Maximum 1 MHz pulse command input
  • Smooth filter function for pulse command, enabled by switch
  • Stop with half rated current
  • FreeMASTER software control interface and monitor
Features
  • MC56F84789
  • Micro-Step Stepper Motor Control
  • MAPS-56F84000 EVK Board
  • MAPS-MC-LV3PH Motor Control Power Stage
Block Diagram
Design Resources
%3CLINGO-SUB%20id%3D%22lingo-sub-1107177%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERDSTEPPER56F84789%3A%20Micro-Step%20Stepper%20Motor%20Control%20Solution%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1107177%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CUL%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNXP-Designs-Knowledge-Base%2FRDSTEPPER56F84789-Micro-Step-Stepper-Motor-Control-Solution%2Fta-p%2F1107177%23toc-hId-380694697%22%20target%3D%22_blank%22%3EOverview%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNXP-Designs-Knowledge-Base%2FRDSTEPPER56F84789-Micro-Step-Stepper-Motor-Control-Solution%2Fta-p%2F1107177%23toc-hId--1426759766%22%20target%3D%22_blank%22%3EFeatures%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNXP-Designs-Knowledge-Base%2FRDSTEPPER56F84789-Micro-Step-Stepper-Motor-Control-Solution%2Fta-p%2F1107177%23toc-hId-1060753067%22%20target%3D%22_blank%22%3EBlock%20Diagram%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNXP-Designs-Knowledge-Base%2FRDSTEPPER56F84789-Micro-Step-Stepper-Motor-Control-Solution%2Fta-p%2F1107177%23toc-hId--746701396%22%20target%3D%22_blank%22%3EDesign%20Resources%3C%2FA%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH1%20id%3D%22toc-hId-380694697%22%20id%3D%22toc-hId-1297637648%22%3EOverview%3C%2FH1%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%23333f48%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2016px%3B%20margin%3A%200px%200px%2011px%3B%22%3EThis%20reference%20design%20is%20based%20on%2032-bit%20DSC%20MC56F84789%2C%20to%20demo%20a%20micro-step%20stepper%20motor%20control%20solution.%20This%20reference%20design%20jump-starts%20your%20ability%20to%20leverage%20the%20NXP%3CSPAN%20style%3D%22font-size%3A%2010.88px%3B%22%3E%3CSUP%3E%C2%AE%3C%2FSUP%3E%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3EDSCs'%20advanced%20feature%20sets%20via%20complete%20software%2C%20tools%20and%20hardware%20platform.%3C%2FP%3E%3CUL%20style%3D%22color%3A%20%23333f48%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2016px%3B%20margin-bottom%3A%2011px%3B%20padding-left%3A%201em%3B%22%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3ETwo%20phases%20four%20wires%20stepper%20motor%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3EMotor%20self-adaptive%20function%2C%20auto%20motor%20parameters%20identification%20and%20control%20system%20adjustment%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3ERated%20peak%20current%20selection%20by%20switch%2C%20the%20maximum%20current%20is%20up%20to%208%20A%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3ESpeed%20ratio%3A%201%20%3A%201000%20with%20position%20and%20speed%20closed%20loop%20control%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3ECurrent%20PID%20regulator%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3EMicro-step%20resolution%20selection%20by%20switch%2C%20the%20maximum%20resolution%20is%20up%20to%2025600%20steps%2Frev%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3EThe%20maximum%20speed%20is%20up%20to%203000RPM%20with%20loading%20capability%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3EPulse%20command%20mode%3A%20single%20pulse%20plus%20direction%20control%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3EMaximum%201%20MHz%20pulse%20command%20input%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3ESmooth%20filter%20function%20for%20pulse%20command%2C%20enabled%20by%20switch%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3EStop%20with%20half%20rated%20current%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3EFreeMASTER%20software%20control%20interface%20and%20monitor%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CH1%20id%3D%22toc-hId--1426759766%22%20id%3D%22toc-hId--509816815%22%3EFeatures%3C%2FH1%3E%3CP%3E%3C%2FP%3E%3CUL%20style%3D%22color%3A%20%23333f48%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2016px%3B%20margin-bottom%3A%2011px%3B%20padding-left%3A%201em%3B%22%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3EMC56F84789%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3EMicro-Step%20Stepper%20Motor%20Control%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3EMAPS-56F84000%20EVK%20Board%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3EMAPS-MC-LV3PH%20Motor%20Control%20Power%20Stage%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CH1%20id%3D%22toc-hId-1060753067%22%20id%3D%22toc-hId-1977696018%22%3EBlock%20Diagram%3C%2FH1%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22RDSTEPPER56F84789-BD.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22RDSTEPPER56F84789-BD.png%22%20style%3D%22width%3A%20672px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F110365i24B188770B08FF07%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22RDSTEPPER56F84789-BD.png%22%20alt%3D%22RDSTEPPER56F84789-BD.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ERDSTEPPER56F84789-BD.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CH1%20id%3D%22toc-hId--746701396%22%20id%3D%22toc-hId-170241555%22%3EDesign%20Resources%3C%2FH1%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1107177%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3ELegacy%20Designs%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
No ratings
Version history
Last update:
‎08-12-2020 08:19 AM
Updated by:
