Industrial Printer
Industrial Printer
Industrial Printer
Overview
NXP's industrial printer solution allows you to leverage the Internet of Things (IoT) technologies and easily integrate a reliable, fast, and secure design that differentiates and provides value to your customers.
NXP provides an extensive technology portfolio including high-performance MPUs with advanced integrated security and connectivity features, cryptographic accelerators, and a 10-15 year product longevity program. This enables designers to successfully develop reliable, high performing, and secure printers.
Interactive Block Diagram
Recommended Products
Category Products Features
MPU i.MX 6SoloX Applications Processors | Arm® Cortex®-A9, Cortex-M4 | NXP
  • 1x Cortex-A9 up to 1 GHz
  • 1x Cortex-M4 up to 200 MHz
  • 24-bit parallel CMOS sensor interface
  • 2x 10/100/1000 Ethernet
  • PCIe 2.0 (1 lane)
  • FlexCAN
  • 5x SPI, 6x UART, 4x I2C, 5x I2S/SSI, 8x PWM
  i.MX 8M Applications Processor | Arm® Cortex®-A53, Cortex-M4 | 4K display resolution | NXP
  • Quad Arm Cortex-A53; Cortex-M4F
  • OpenGL® ES 3.1, OpenGL® 3.0,Vulkan®, Open CL™ 1.2
  • Dual PCIe with L1 substates for fast wake-up from low-power mode
  • Gigabit Ethernet controller supporting AVB and EEE
  • 4x PWM, 3X SPI, 4X I2C
Secure Authenticator A1006 | Secure Authenticator IC: Embedded Security Platform | NXP
  • Authentication time (on-chip calculations) < 50 ms
  • Unique static pair of ECC Private Key
  • Power Consumption: 500 μA active
RTC PCF8523 | NXP
  • Provides year, month, day, weekday, hours, minutes, and seconds based on a 32.768 kHz quartz crystal.
  • Resolution: seconds to years.
Load Switch USB PD and type C current-limited power switch | NXP
  • VIN supply voltage range from 4.0 V to 5.5 V
  • All-time reverse current protection with ultra-fast RCP recovery
  • Adjustable current limit from 400 mA to 3.3 adjustable current limits from 400 mA to 3.3 A
  • Clamped current output in the over-current condition
USB Type-C PTN5150 | NXP
  • Compatible with legacy OTG hardware and software
  • Support plug, orientation, role and charging current detection
Level Translator Voltage Level Translators (Level Shifters) | NXP
  • Bi-directional level shifter and translator circuits include a range from single-bit to 32-bit widths
GPIO Expander PCAL6416AEX | NXP
  • The 16-bit general-purpose I/O expander
  • Latched outputs with 25 mA drive maximum capability
  • The operating power supply voltage range of 1.65 V to 5.5 V
PMIC 14-Channel Configurable Power Management IC | NXP
  • Four to six buck regulators depending on configuration, Single/dual phase/parallel options, DDR termination tracking mode option, DVS option
  • 5V boost regulator for USB OTG
CAN Transceiver TJA1057 | High Speed CAN Transceiver | NXP
  • VIO option allows for direct interfacing with 3.3 V and 5 V-supplied microcontrollers I2S port to allow routing to the applications processor
  • Functional behavior predictable under all supply conditions
  • Thermally protected
AC/DC AC-DC Solutions | NXP
  • Increased efficiency and no-load power of the total application
  • Universal mains operation: 90 - 264 Vac / 47 - 63Hz
  • Over Current Protection (OCP), Over Power Protection (OPP), Over Temperature Protection (OTP)
Motor Driver Dual H-Bridge Motor Driver 2-8.6 V 1.4 A 200 kHz | NXP
  • Low Total RDS(ON) 0.8 Ω (Typ), 1.2 Ω (Max) @ 25°C
  • Undervoltage Detection and Shutdown Circuit
  • Output Current 0.7 A (DC)
Temperature Sensor PCT2075: I2C-bus Fm+, 1 Degree C Accuracy | NXP
  • Pin-for-pin replacement for LM75 series but allows up to 27 devices on the bus
  • Power supply range from 2.7 V to 5.5 V
  • Temperatures range from -55 °C to +125 °C
Wireless MCU Arm® Cortex®-M0+|Kinetis® KW41Z 2.4 GHz Bluetooth Low Energy Thread Zigbee Radio MCUs | NXP
  • 2.4 GHz Bluetooth Low Energy version 4.2 Compliant
  • IEEE Std. 802.15.4 Standard Compliant
  • AES-128 Accelerator (AESA), True Random Number Generator (TRNG)
标签 (1)
%3CLINGO-SUB%20id%3D%22lingo-sub-1110042%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%B7%A5%E4%B8%9A%E6%89%93%E5%8D%B0%E6%9C%BA%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1110042%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%20style%3D%22color%3A%20%2320272d%3B%20background-color%3A%20%23ffffff%3B%20font-weight%3A%20bold%3B%20font-size%3A%201.35em%3B%20margin-top%3A%2022px%3B%20margin-bottom%3A%200.5em%3B%22%3E%3CUL%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A50px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNXP-Designs-Knowledge-Base%2FIndustrial-Printer%2Fta-p%2F1110042%23toc-hId-1082473200%22%20target%3D%22_blank%22%3EOverview%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A50px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNXP-Designs-Knowledge-Base%2FIndustrial-Printer%2Fta-p%2F1110042%23toc-hId--724981263%22%20target%3D%22_blank%22%3E%E4%BA%A4%E4%BA%92%E5%BC%8F%E6%A1%86%E5%9B%BE%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A50px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNXP-Designs-Knowledge-Base%2FIndustrial-Printer%2Fta-p%2F1110042%23toc-hId-1762531570%22%20target%3D%22_blank%22%3E%E6%8E%A8%E8%8D%90%E4%BA%A7%E5%93%81%3C%2FA%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FP%3E%0A%3CH3%20style%3D%22color%3A%20%2320272d%3B%20background-color%3A%20%23ffffff%3B%20font-weight%3A%20bold%3B%20font-size%3A%201.35em%3B%20margin-top%3A%2022px%3B%20margin-bottom%3A%200.5em%3B%22%20id%3D%22toc-hId-1082473200%22%20id%3D%22toc-hId-2005280144%22%3EOverview%3C%2FH3%3E%0A%3CP%3ENXP%20%E7%9A%84%E5%B7%A5%E4%B8%9A%E6%89%93%E5%8D%B0%E6%9C%BA%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%E4%BD%BF%E6%82%A8%E8%83%BD%E5%A4%9F%E5%88%A9%E7%94%A8%E7%89%A9%E8%81%94%E7%BD%91%20(IoT)%20%E6%8A%80%E6%9C%AF%EF%BC%8C%E8%BD%BB%E6%9D%BE%E9%9B%86%E6%88%90%E5%8F%AF%E9%9D%A0%E3%80%81%E5%BF%AB%E9%80%9F%E3%80%81%E5%AE%89%E5%85%A8%E7%9A%84%E8%AE%BE%E8%AE%A1%EF%BC%8C%E4%BB%8E%E8%80%8C%E4%B8%BA%E6%82%A8%E7%9A%84%E5%AE%A2%E6%88%B7%E6%8F%90%E4%BE%9B%E5%B7%AE%E5%BC%82%E5%8C%96%E5%92%8C%E4%BB%B7%E5%80%BC%E3%80%82%3C%2FP%3E%0A%3CP%3ENXP%20%E6%8F%90%E4%BE%9B%E5%B9%BF%E6%B3%9B%E7%9A%84%E6%8A%80%E6%9C%AF%E7%BB%84%E5%90%88%EF%BC%8C%E5%8C%85%E6%8B%AC%E5%85%B7%E6%9C%89%E5%85%88%E8%BF%9B%E9%9B%86%E6%88%90%E5%AE%89%E5%85%A8%E6%80%A7%E5%92%8C%E8%BF%9E%E6%8E%A5%E5%8A%9F%E8%83%BD%E7%9A%84%E9%AB%98%E6%80%A7%E8%83%BD%20MPU%E3%80%81%E5%8A%A0%E5%AF%86%E5%8A%A0%E9%80%9F%E5%99%A8%E4%BB%A5%E5%8F%8A%2010-15%20%E5%B9%B4%E4%BA%A7%E5%93%81%E5%AF%BF%E5%91%BD%E8%AE%A1%E5%88%92%E3%80%82%E8%BF%99%E4%BD%BF%E8%AE%BE%E8%AE%A1%E5%B8%88%E8%83%BD%E5%A4%9F%E6%88%90%E5%8A%9F%E5%BC%80%E5%8F%91%E5%8F%AF%E9%9D%A0%E3%80%81%E9%AB%98%E6%80%A7%E8%83%BD%E4%B8%94%E5%AE%89%E5%85%A8%E7%9A%84%E6%89%93%E5%8D%B0%E6%9C%BA%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CH3%20id%3D%22toc-hId--724981263%22%20id%3D%22toc-hId-197825681%22%3E%E4%BA%A4%E4%BA%92%E5%BC%8F%E6%A1%86%E5%9B%BE%3C%2FH3%3E%0A%3CP%3E%3CIMG%20style%3D%22display%3A%20block%3B%20margin-left%3A%20auto%3B%20margin-right%3A%20auto%3B%22%20class%3D%22j-img-centered%22%20src%3D%22https%3A%2F%2Fwww.nxp.com%2Fassets%2Fimages%2Fen%2Fblock-diagrams%2FINDPRINTER-BD.jpg%22%20border%3D%220%22%20width%3D%22740%22%20height%3D%22416%22%20%2F%3E%3C%2FP%3E%0A%3CH3%20id%3D%22toc-hId-1762531570%22%20id%3D%22toc-hId--1609628782%22%3E%E6%8E%A8%E8%8D%90%E4%BA%A7%E5%93%81%3C%2FH3%3E%0A%3CBR%20%2F%3E%0A%3CTABLE%20class%3D%22j-table%20jiveBorder%22%20style%3D%22border%3A%201px%20solid%20%23c6c6c6%3B%22%20width%3D%22100%25%22%3E%0A%3CTBODY%20style%3D%22border%3A%20inherit%20solid%20inherit%3B%22%3E%0A%3CTR%20style%3D%22background-color%3A%20%2352cc8f%3B%20height%3A%2025px%3B%22%3E%0A%3CTD%20style%3D%22font-size%3A%20inherit%3B%20padding%3A%205px%3B%20width%3A%2013%25%3B%20height%3A%2025px%3B%22%3E%3CSTRONG%3E%E7%B1%BB%E5%88%AB%3C%2FSTRONG%3E%3C%2FTD%3E%0A%3CTD%20style%3D%22font-size%3A%20inherit%3B%20padding%3A%205px%3B%20width%3A%2039.8513%25%3B%20height%3A%2025px%3B%22%3E%3CSTRONG%3E%E4%BA%A7%E5%93%81%3C%2FSTRONG%3E%3C%2FTD%3E%0A%3CTD%20style%3D%22font-size%3A%20inherit%3B%20padding%3A%205px%3B%20width%3A%20103.149%25%3B%20height%3A%2025px%3B%22%3E%3CSTRONG%3E%E7%89%B9%E6%80%A7%3C%2FSTRONG%3E%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%20style%3D%22height%3A%20211px%3B%22%3E%0A%3CTD%20style%3D%22font-size%3A%20inherit%3B%20padding%3A%205px%3B%20width%3A%2013%25%3B%20height%3A%20211px%3B%22%3E%3CSTRONG%3EMPU%3C%2FSTRONG%3E%3C%2FTD%3E%0A%3CTD%20style%3D%22font-size%3A%20inherit%3B%20padding%3A%205px%3B%20width%3A%2039.8513%25%3B%20height%3A%20211px%3B%22%3E%3CA%20class%3D%22link-titled%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fprocessors-and-microcontrollers%2Farm-processors%2Fi-mx-applications-processors%2Fi-mx-6-processors%2Fi-mx-6solox-processors-heterogeneous-processing-with-arm-cortex-a9-and-cortex-m4-cores%3Ai.MX6SX%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fprocessors-and-microcontrollers%2Farm-processors%2Fi-mx-applications-processors%2Fi-mx-6-processors%2Fi-mx-6solox-processors-heterogeneous-processing-with-arm-cortex-a9-and-cortex-m4-cores%3Ai.MX6SX%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ei.MX%206SoloX%20%E5%BA%94%E7%94%A8%E5%A4%84%E7%90%86%E5%99%A8%20%7C%20Arm%20%C2%AE%20Cortex%20%C2%AE%20-A9%E3%80%81Cortex-M4%20%7C%20NXP%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20style%3D%22font-size%3A%20inherit%3B%20padding%3A%205px%3B%20width%3A%20103.149%25%3B%20height%3A%20211px%3B%22%3E%0A%3CUL%3E%0A%3CLI%3E1%E4%B8%AACortex-A9%EF%BC%8C%E8%BF%90%E8%A1%8C%E9%A2%91%E7%8E%87%E9%AB%98%E8%BE%BE1%20GHz%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%23333f48%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2016px%3B%22%3E%3CSPAN%3E1%E4%B8%AACortex-M4%EF%BC%8C%E8%BF%90%E8%A1%8C%E9%A2%91%E7%8E%87%E9%AB%98%E8%BE%BE200%20MHz%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20color%3A%20%23333f48%3B%20font-size%3A%2016px%3B%22%3E24%E4%BD%8D%E5%B9%B6%E8%A1%8CCMOS%E4%BC%A0%E6%84%9F%E5%99%A8%E6%8E%A5%E5%8F%A3%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20color%3A%20%23333f48%3B%20font-size%3A%2016px%3B%22%3E2x%2010%2F100%2F1000%E4%BB%A5%E5%A4%AA%E7%BD%91%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20color%3A%20%23333f48%3B%20font-size%3A%2016px%3B%22%3EPCIe%202.0%20(1%20lane)%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20color%3A%20%23333f48%3B%20font-size%3A%2016px%3B%22%3EFlexCAN%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20color%3A%20%23333f48%3B%20font-size%3A%2016px%3B%22%3E5%20%E4%B8%AA%20SPI%E3%80%816%20%E4%B8%AA%20UART%E3%80%814%20%E4%B8%AA%20I2C%E3%80%815%20%E4%B8%AA%20I2S%2FSSI%E3%80%818%20%E4%B8%AA%20PWM%3C%2FSPAN%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%20style%3D%22height%3A%20153px%3B%22%3E%0A%3CTD%20style%3D%22font-size%3A%20inherit%3B%20padding%3A%205px%3B%20width%3A%2013%25%3B%20height%3A%20153px%3B%22%3E%26nbsp%3B%3C%2FTD%3E%0A%3CTD%20style%3D%22font-size%3A%20inherit%3B%20padding%3A%205px%3B%20width%3A%2039.8513%25%3B%20height%3A%20153px%3B%22%3E%3CA%20class%3D%22link-titled%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fprocessors-and-microcontrollers%2Farm-processors%2Fi-mx-applications-processors%2Fi-mx-8-processors%2Fi-mx-8m-family-armcortex-a53-cortex-m4-audio-voice-video%3Ai.MX8M%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fprocessors-and-microcontrollers%2Farm-processors%2Fi-mx-applications-processors%2Fi-mx-8-processors%2Fi-mx-8m-family-armcortex-a53-cortex-m4-audio-voice-video%3Ai.MX8M%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ei.MX%208M%20%E5%BA%94%E7%94%A8%E5%A4%84%E7%90%86%E5%99%A8%20%7C%20Arm%20%C2%AE%20Cortex%20%C2%AE%20-A53%E3%80%81Cortex-M4%20%7C%204K%20%E6%98%BE%E7%A4%BA%E5%88%86%E8%BE%A8%E7%8E%87%20%7C%20NXP%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20style%3D%22font-size%3A%20inherit%3B%20padding%3A%205px%3B%20width%3A%20103.149%25%3B%20height%3A%20153px%3B%22%3E%0A%3CUL%3E%0A%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%23333f48%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2016px%3B%22%3E%E5%9B%9B%E6%A0%B8Arm%20Cortex-A53%3B%20Cortex-M4F%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%23333f48%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2016px%3B%22%3EOpenGL%C2%AE%20ES%203.1%2C%20OpenGL%C2%AE%203.0%2CVulkan%C2%AE%2C%20Open%20CL%E2%84%A2%201.2%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%23333f48%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2016px%3B%22%3E%E6%8F%90%E4%BE%9BL1%E5%AD%90%E7%8A%B6%E6%80%81%E7%9A%84%E5%8F%8CPCIe%EF%BC%8C%E5%85%B7%E6%9C%89%E4%BB%8E%E4%BD%8E%E5%8A%9F%E8%80%97%E6%A8%A1%E5%BC%8F%E5%BF%AB%E9%80%9F%E5%94%A4%E9%86%92%E5%8A%9F%E8%83%BD%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%23333f48%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2016px%3B%22%3E%E5%85%B7%E6%9C%89%E6%94%AF%E6%8C%81AVB%E5%92%8CEEE%E7%9A%84%E5%8D%83%E5%85%86%E4%BB%A5%E5%A4%AA%E7%BD%91%E6%8E%A7%E5%88%B6%E5%99%A8%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%23333f48%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2016px%3B%22%3E4%20%E4%B8%AA%20PWM%E3%80%813%20%E4%B8%AA%20SPI%E3%80%814%20%E4%B8%AA%20I2C%3C%2FSPAN%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%20style%3D%22height%3A%2091px%3B%22%3E%0A%3CTD%20style%3D%22font-size%3A%20inherit%3B%20padding%3A%205px%3B%20width%3A%2013%25%3B%20height%3A%2091px%3B%22%3E%3CSTRONG%3E%E5%AE%89%E5%85%A8%E8%AE%A4%E8%AF%81%E5%99%A8%3C%2FSTRONG%3E%3C%2FTD%3E%0A%3CTD%20style%3D%22font-size%3A%20inherit%3B%20padding%3A%205px%3B%20width%3A%2039.8513%25%3B%20height%3A%2091px%3B%22%3E%3CA%20class%3D%22link-titled%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fsecurity-and-authentication%2Fauthentication%2Fsecure-authenticator-ic-embedded-security-platform%3AA1006%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fsecurity-and-authentication%2Fauthentication%2Fsecure-authenticator-ic-embedded-security-platform%3AA1006%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EA1006%20%7C%20%E5%AE%89%E5%85%A8%E8%AE%A4%E8%AF%81%E5%99%A8%20IC%EF%BC%9A%E5%B5%8C%E5%85%A5%E5%BC%8F%E5%AE%89%E5%85%A8%E5%B9%B3%E5%8F%B0%20%7C%20NXP%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20style%3D%22padding%3A%205px%3B%20width%3A%20103.149%25%3B%20height%3A%2091px%3B%22%3E%0A%3CUL%3E%0A%3CLI%20style%3D%22font-size%3A%20inherit%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23333f48%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2016px%3B%22%3E%3CSPAN%3E%E8%AE%A4%E8%AF%81%E6%97%B6%E9%97%B4(%E7%89%87%E4%B8%8A%E8%AE%A1%E7%AE%97)%20%26lt%3B%2050%20ms%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20color%3A%20%23333f48%3B%20font-size%3A%2016px%3B%22%3E%E5%94%AF%E4%B8%80%E9%9D%99%E6%80%81%20ECC%20%E7%A7%81%E9%92%A5%E5%AF%B9%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%2320272d%3B%20font-size%3A%2014px%3B%22%3E%E5%8A%9F%E8%80%97%EF%BC%9A%E6%B4%BB%E5%8A%A8%E7%8A%B6%E6%80%81%E4%B8%BA500%20%CE%BCA%3C%2FSPAN%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%20style%3D%22height%3A%2027px%3B%22%3E%0A%3CTD%20style%3D%22font-size%3A%20inherit%3B%20padding%3A%205px%3B%20width%3A%2013%25%3B%20height%3A%2027px%3B%22%3E%3CSTRONG%3ERTC%3C%2FSTRONG%3E%3C%2FTD%3E%0A%3CTD%20style%3D%22font-size%3A%20inherit%3B%20padding%3A%205px%3B%20width%3A%2039.8513%25%3B%20height%3A%2027px%3B%22%3E%3CA%20class%3D%22link-titled%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fperipherals-and-logic%2Fsignal-chain%2Freal-time-clocks%2Frtcs-with-ic-bus%2F100-na-real-time-clock-calendar-with-battery-backup%3APCF8523%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fperipherals-and-logic%2Fsignal-chain%2Freal-time-clocks%2Frtcs-with-ic-bus%2F100-na-real-time-clock-calendar-with-battery-backup%3APCF8523%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EPCF8523%20%7C%20NXP%3C%2FA%3E%26nbsp%3B%3C%2FTD%3E%0A%3CTD%20style%3D%22padding%3A%205px%3B%20width%3A%20103.149%25%3B%20height%3A%2027px%3B%22%3E%0A%3CUL%3E%0A%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%23333f48%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2016px%3B%22%3E%3CSPAN%3E%E5%9F%BA%E4%BA%8E%2032.768%20kHz%20%E7%9F%B3%E8%8B%B1%E6%99%B6%E4%BD%93%E6%8F%90%E4%BE%9B%E5%B9%B4%E3%80%81%E6%9C%88%E3%80%81%E6%97%A5%E3%80%81%E5%91%A8%E3%80%81%E6%97%B6%E3%80%81%E5%88%86%E5%92%8C%E7%A7%92%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%23333f48%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2016px%3B%22%3E%3CSPAN%3E%E5%88%86%E8%BE%A8%E7%8E%87%EF%BC%9A%E7%A7%92%E8%87%B3%E5%B9%B4%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%20style%3D%22height%3A%2027px%3B%22%3E%0A%3CTD%20style%3D%22font-size%3A%20inherit%3B%20padding%3A%205px%3B%20width%3A%2013%25%3B%20height%3A%2027px%3B%22%3E%3CSTRONG%3E%E8%B4%9F%E8%BD%BD%E5%BC%80%E5%85%B3%3C%2FSTRONG%3E%3C%2FTD%3E%0A%3CTD%20style%3D%22font-size%3A%20inherit%3B%20padding%3A%205px%3B%20width%3A%2039.8513%25%3B%20height%3A%2027px%3B%22%3E%3CA%20class%3D%22link-titled%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fpower-management%2Fload-switches%2Fusb-pd-and-type-c-current-limited-power-switch%3ANX5P3290UK%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fpower-management%2Fload-switches%2Fusb-pd-and-type-c-current-limited-power-switch%3ANX5P3290UK%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EUSB%20PD%20%E5%92%8C%20Type%20C%20%E9%99%90%E6%B5%81%E7%94%B5%E6%BA%90%E5%BC%80%E5%85%B3%20%7C%20NXP%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20style%3D%22padding%3A%205px%3B%20width%3A%20103.149%25%3B%20height%3A%2027px%3B%22%3E%0A%3CUL%3E%0A%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%23333f48%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2016px%3B%22%3E%3CSPAN%3EVIN%E7%94%B5%E6%BA%90%E7%94%B5%E5%8E%8B%E8%8C%83%E5%9B%B4%EF%BC%9A4.0V%E8%87%B35.5V%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%23333f48%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2016px%3B%22%3E%3CSPAN%3E%E5%A7%8B%E7%BB%88%E6%8F%90%E4%BE%9B%E5%8F%8D%E5%90%91%E7%94%B5%E6%B5%81%E4%BF%9D%E6%8A%A4%EF%BC%8C%E5%85%B7%E6%9C%89%E8%B6%85%E5%BF%ABRCP%E6%81%A2%E5%A4%8D%E5%8A%9F%E8%83%BD%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%23333f48%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2016px%3B%22%3E%3CSPAN%3E%E5%8F%AF%E8%B0%83%E7%94%B5%E6%B5%81%E9%99%90%E5%88%B6%E4%BB%8E%20400%20mA%20%E5%88%B0%203.3%20%E5%8F%AF%E8%B0%83%E7%94%B5%E6%B5%81%E9%99%90%E5%88%B6%E4%BB%8E%20400%20mA%20%E5%88%B0%203.3%20A%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%23333f48%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2016px%3B%22%3E%3CSPAN%3E%E5%9C%A8%E8%BF%87%E6%B5%81%E6%83%85%E5%86%B5%E4%B8%8B%E9%92%B3%E4%BD%8D%E7%94%B5%E6%B5%81%E8%BE%93%E5%87%BA%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%20style%3D%22height%3A%2027px%3B%22%3E%0A%3CTD%20style%3D%22font-size%3A%20inherit%3B%20padding%3A%205px%3B%20width%3A%2013%25%3B%20height%3A%2027px%3B%22%3E%3CSTRONG%3EUSB%20Type-C%3C%2FSTRONG%3E%3C%2FTD%3E%0A%3CTD%20style%3D%22font-size%3A%20inherit%3B%20padding%3A%205px%3B%20width%3A%2039.8513%25%3B%20height%3A%2027px%3B%22%3E%3CA%20class%3D%22link-titled%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Finterfaces%2Fusb-interfaces%2Fusb-type-c-true-plugn-play%2Fusb-pd-phy-and-cc-logic%2Fcc-logic-for-usb-type-c-applications%3APTN5150%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Finterfaces%2Fusb-interfaces%2Fusb-type-c-true-plugn-play%2Fusb-pd-phy-and-cc-logic%2Fcc-logic-for-usb-type-c-applications%3APTN5150%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EPTN5150%20%7C%20%E6%81%A9%E6%99%BA%E6%B5%A6%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20style%3D%22padding%3A%205px%3B%20width%3A%20103.149%25%3B%20height%3A%2027px%3B%22%3E%0A%3CUL%3E%0A%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%23333f48%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2016px%3B%22%3E%3CSPAN%3E%E4%B8%8E%E6%97%A7%E7%89%88OTG%E7%A1%AC%E4%BB%B6%E5%92%8C%E8%BD%AF%E4%BB%B6%E5%85%BC%E5%AE%B9%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%23333f48%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2016px%3B%22%3E%3CSPAN%3E%E6%94%AF%E6%8C%81%E6%8F%92%E5%A4%B4%E3%80%81%E6%96%B9%E5%90%91%E3%80%81%E8%A7%92%E8%89%B2%E5%92%8C%E5%85%85%E7%94%B5%E7%94%B5%E6%B5%81%E6%A3%80%E6%B5%8B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%20style%3D%22height%3A%2027px%3B%22%3E%0A%3CTD%20style%3D%22font-size%3A%20inherit%3B%20padding%3A%205px%3B%20width%3A%2013%25%3B%20height%3A%2027px%3B%22%3E%3CSTRONG%3E%E7%94%B5%E5%B9%B3%E8%BD%AC%E6%8D%A2%E5%99%A8%3C%2FSTRONG%3E%3C%2FTD%3E%0A%3CTD%20style%3D%22font-size%3A%20inherit%3B%20padding%3A%205px%3B%20width%3A%2039.8513%25%3B%20height%3A%2027px%3B%22%3E%3CA%20class%3D%22link-titled%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fperipherals-and-logic%2Fvolt-level-translators%3AVOLTAGE-LEVEL-TRANSLATORS%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fperipherals-and-logic%2Fvoltage-level-translators%3AVOLTAGE-LEVEL-TRANSLATORS%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%E7%94%B5%E5%8E%8B%E7%94%B5%E5%B9%B3%E8%BD%AC%E6%8D%A2%E5%99%A8%EF%BC%88%E7%94%B5%E5%B9%B3%E7%A7%BB%E4%BD%8D%E5%99%A8%EF%BC%89%7C%20NXP%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20style%3D%22padding%3A%205px%3B%20width%3A%20103.149%25%3B%20height%3A%2027px%3B%22%3E%0A%3CUL%3E%0A%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%23333f48%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2016px%3B%22%3E%3CSPAN%3E%E5%8F%8C%E5%90%91%E7%94%B5%E5%B9%B3%E4%BD%8D%E7%A7%BB%E5%99%A8%E5%92%8C%E8%BD%AC%E6%8D%A2%E5%99%A8%E7%94%B5%E8%B7%AF%E5%8C%85%E6%8B%AC%E4%BB%8E%E5%8D%95%E4%B8%AA%E4%BD%8D%E5%88%B0%2032%20%E4%BD%8D%E5%AE%BD%E5%BA%A6%E7%9A%84%E8%8C%83%E5%9B%B4%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%20style%3D%22height%3A%2027px%3B%22%3E%0A%3CTD%20style%3D%22font-size%3A%20inherit%3B%20padding%3A%205px%3B%20width%3A%2013%25%3B%20height%3A%2027px%3B%22%3E%3CSTRONG%3EGPIO%E6%89%A9%E5%B1%95%E5%99%A8%3C%2FSTRONG%3E%3C%2FTD%3E%0A%3CTD%20style%3D%22font-size%3A%20inherit%3B%20padding%3A%205px%3B%20width%3A%2039.8513%25%3B%20height%3A%2027px%3B%22%3E%3CA%20class%3D%22link-titled%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Finterfaces%2Fic-spi-serial-interface-devices%2Fic-general-purpose-io%2Flow-volt-translating-16-bit-ic-bus-smbus-io-expander%3APCAL6416AEX%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Finterfaces%2Fic-spi-serial-interface-devices%2Fic-general-purpose-i-o%2Flow-voltage-translating-16-bit-ic-bus-smbus-i-o-expander%3APCAL6416AEX%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EPCAL6416AEX%20%7C%20NXP%3C%2FA%3E%26nbsp%3B%3C%2FTD%3E%0A%3CTD%20style%3D%22padding%3A%205px%3B%20width%3A%20103.149%25%3B%20height%3A%2027px%3B%22%3E%0A%3CUL%3E%0A%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%23333f48%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2016px%3B%22%3E%3CSPAN%3E16%E4%BD%8D%E9%80%9A%E7%94%A8I%2FO%E6%89%A9%E5%B1%95%E5%99%A8%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%23333f48%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2016px%3B%22%3E%3CSPAN%3E%E9%94%81%E5%AD%98%E8%BE%93%E5%87%BA%E5%85%B7%E6%9C%8925%20mA%E7%9A%84%E6%9C%80%E5%A4%A7%E9%A9%B1%E5%8A%A8%E8%83%BD%E5%8A%9B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%23333f48%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2016px%3B%22%3E%3CSPAN%3E%E5%B7%A5%E4%BD%9C%E7%94%B5%E6%BA%90%E7%94%B5%E5%8E%8B%E8%8C%83%E5%9B%B4%E4%B8%BA1.65%20V%E8%87%B35.5%20V%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%20style%3D%22height%3A%2027px%3B%22%3E%0A%3CTD%20style%3D%22font-size%3A%20inherit%3B%20padding%3A%205px%3B%20width%3A%2013%25%3B%20height%3A%2027px%3B%22%3E%3CSTRONG%3EPMIC%3C%2FSTRONG%3E%3C%2FTD%3E%0A%3CTD%20style%3D%22font-size%3A%20inherit%3B%20padding%3A%205px%3B%20width%3A%2039.8513%25%3B%20height%3A%2027px%3B%22%3E%3CA%20class%3D%22link-titled%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fpower-management%2Fpmics%2Fpmics-for-i-mx-applications-processors%2F14-channel-configurable-power-management-ic%3AMMPF0100%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fpower-management%2Fpmics%2Fpmics-for-i-mx-applications-processors%2F14-channel-configurable-power-management-ic%3AMMPF0100%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E14%E9%80%9A%E9%81%93%E5%8F%AF%E9%85%8D%E7%BD%AE%E7%94%B5%E6%BA%90%E7%AE%A1%E7%90%86IC%20%7C%20NXP%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20style%3D%22padding%3A%205px%3B%20width%3A%20103.149%25%3B%20height%3A%2027px%3B%22%3E%0A%3CUL%3E%0A%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%23333f48%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2016px%3B%22%3E%3CSPAN%3E%E6%A0%B9%E6%8D%AE%E9%85%8D%E7%BD%AE%E3%80%81%E5%8D%95%2F%E5%8F%8C%E7%9B%B8%2F%E5%B9%B6%E8%A1%8C%E9%80%89%E9%A1%B9%E3%80%81DDR%E7%BB%88%E6%AD%A2%E8%B7%9F%E8%B8%AA%E6%A8%A1%E5%BC%8F%E9%80%89%E9%A1%B9%E3%80%81DVS%E9%80%89%E9%A1%B9%EF%BC%8C%E5%8F%AF%E8%AE%BE%E7%BD%AE4%E8%87%B36%E4%B8%AA%E9%99%8D%E5%8E%8B%E7%A8%B3%E5%8E%8B%E5%99%A8%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%23333f48%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2016px%3B%22%3E%3CSPAN%3E5V%E5%8D%87%E5%8E%8B%E7%A8%B3%E5%8E%8B%E5%99%A8%EF%BC%8C%E7%94%A8%E4%BA%8EUSB%20OTG%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%20style%3D%22height%3A%2027px%3B%22%3E%0A%3CTD%20style%3D%22font-size%3A%20inherit%3B%20padding%3A%205px%3B%20width%3A%2013%25%3B%20height%3A%2027px%3B%22%3E%3CSTRONG%3ECAN%E6%94%B6%E5%8F%91%E5%99%A8%3C%2FSTRONG%3E%3C%2FTD%3E%0A%3CTD%20style%3D%22font-size%3A%20inherit%3B%20padding%3A%205px%3B%20width%3A%2039.8513%25%3B%20height%3A%2027px%3B%22%3E%3CA%20class%3D%22link-titled%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Finterfaces%2Fcan-transceivers%2Fcan-with-flexible-data-rate%2Fhigh-speed-can-transceiver-mantis-family%3ATJA1057%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Finterfaces%2Fcan-transceivers%2Fcan-with-flexible-data-rate%2Fhigh-speed-can-transceiver-mantis-family%3ATJA1057%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ETJA1057%20%7C%20%E9%AB%98%E9%80%9FCAN%E6%94%B6%E5%8F%91%E5%99%A8%20%7C%20%E6%81%A9%E6%99%BA%E6%B5%A6%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20style%3D%22padding%3A%205px%3B%20width%3A%20103.149%25%3B%20height%3A%2027px%3B%22%3E%0A%3CUL%3E%0A%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%23333f48%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2016px%3B%22%3E%3CSPAN%3EVIO%20%E9%80%89%E9%A1%B9%E5%85%81%E8%AE%B8%E7%9B%B4%E6%8E%A5%E4%B8%8E%203.3%20V%20%E5%92%8C%205%20V%20%E4%BE%9B%E7%94%B5%E7%9A%84%E5%BE%AE%E6%8E%A7%E5%88%B6%E5%99%A8%20I2S%20%E7%AB%AF%E5%8F%A3%E8%BF%9E%E6%8E%A5%EF%BC%8C%E4%BB%A5%E5%85%81%E8%AE%B8%E8%B7%AF%E7%94%B1%E8%87%B3%E5%BA%94%E7%94%A8%E5%A4%84%E7%90%86%E5%99%A8%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%23333f48%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2016px%3B%22%3E%3CSPAN%3E%E6%89%80%E6%9C%89%E4%BE%9B%E7%94%B5%E7%8A%B6%E6%80%81%E4%B8%8B%E7%9A%84%E5%8A%9F%E8%83%BD%E6%93%8D%E4%BD%9C%E5%9D%87%E5%8F%AF%E9%A2%84%E6%B5%8B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%23333f48%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2016px%3B%22%3E%3CSPAN%3E%E8%BF%87%E7%83%AD%E4%BF%9D%E6%8A%A4%E5%8A%9F%E8%83%BD%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%20style%3D%22height%3A%2027px%3B%22%3E%0A%3CTD%20style%3D%22font-size%3A%20inherit%3B%20padding%3A%205px%3B%20width%3A%2013%25%3B%20height%3A%2027px%3B%22%3E%3CSTRONG%3EAC%2FDC%3C%2FSTRONG%3E%3C%2FTD%3E%0A%3CTD%20style%3D%22font-size%3A%20inherit%3B%20padding%3A%205px%3B%20width%3A%2039.8513%25%3B%20height%3A%2027px%3B%22%3E%3CA%20class%3D%22link-titled%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fpower-management%2Fac-dc-solutions%3AMC_34098%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fpower-management%2Fac-dc-solutions%3AMC_34098%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EAC-DC%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%20%7C%20NXP%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20style%3D%22padding%3A%205px%3B%20width%3A%20103.149%25%3B%20height%3A%2027px%3B%22%3E%0A%3CUL%3E%0A%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%23333f48%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2016px%3B%22%3E%3CSPAN%3E%E6%8F%90%E9%AB%98%E6%95%B4%E4%B8%AA%E5%BA%94%E7%94%A8%E7%9A%84%E6%95%88%E7%8E%87%E5%92%8C%E7%A9%BA%E8%BD%BD%E5%8A%9F%E7%8E%87%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%23333f48%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2016px%3B%22%3E%3CSPAN%3E%E9%80%9A%E7%94%A8%E5%B8%82%E7%94%B5%E5%B7%A5%E4%BD%9C%E7%94%B5%E5%8E%8B%EF%BC%9A85%20-%20264%20Vac%20%2F%2047%20-%2063Hz%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%23333f48%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2016px%3B%22%3E%3CSPAN%3E%E8%BF%87%E6%B5%81%E4%BF%9D%E6%8A%A4(OCP)%E3%80%81%E8%BF%87%E5%8A%9F%E7%8E%87%E4%BF%9D%E6%8A%A4(OPP)%E3%80%81%E8%BF%87%E6%B8%A9%E4%BF%9D%E6%8A%A4(OTP)%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%20style%3D%22height%3A%2027px%3B%22%3E%0A%3CTD%20style%3D%22font-size%3A%20inherit%3B%20padding%3A%205px%3B%20width%3A%2013%25%3B%20height%3A%2027px%3B%22%3E%3CSTRONG%3E%E7%94%B5%E6%9C%BA%E9%A9%B1%E5%8A%A8%E5%99%A8%3C%2FSTRONG%3E%3C%2FTD%3E%0A%3CTD%20style%3D%22font-size%3A%20inherit%3B%20padding%3A%205px%3B%20width%3A%2039.8513%25%3B%20height%3A%2027px%3B%22%3E%3CA%20class%3D%22link-titled%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fpower-management%2Fmotor-and-solenoid-drivers%2Fbldc-h-bridge-stepper%2Fdual-h-bridge-motor-driver-2-8-6-v-1-4-a-200-khz%3AMPC17531%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fpower-management%2Fmotor-and-solenoid-drivers%2Fbldc-h-bridge-stepper%2Fdual-h-bridge-motor-driver-2-8-6-v-1-4-a-200-khz%3AMPC17531%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%E5%8F%8C%20H%20%E6%A1%A5%E7%94%B5%E6%9C%BA%E9%A9%B1%E5%8A%A8%E5%99%A8%202-8.6%20V%201.4%20A%20200%20kHz%20%7C%20NXP%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20style%3D%22padding%3A%205px%3B%20width%3A%20103.149%25%3B%20height%3A%2027px%3B%22%3E%0A%3CUL%3E%0A%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%23333f48%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2016px%3B%22%3E%3CSPAN%3E%E6%80%BB%E5%AF%BC%E9%80%9A%E7%94%B5%E9%98%BB%E4%BD%8E%EF%BC%8C0.8%E2%84%A6%20(%E5%85%B8%E5%9E%8B%E5%80%BC)%EF%BC%8C1.2%E2%84%A6%20(%E6%9C%80%E5%A4%A7%E5%80%BC)%20%40%2025%C2%B0C%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%23333f48%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2016px%3B%22%3E%3CSPAN%3E%E6%AC%A0%E5%8E%8B%E6%A3%80%E6%B5%8B%E5%92%8C%E5%85%B3%E6%96%AD%E7%94%B5%E8%B7%AF%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%23333f48%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2016px%3B%22%3E%3CSPAN%3E%E8%BE%93%E5%87%BA%E7%94%B5%E6%B5%81%EF%BC%9A0.7A%20(DC)%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%20style%3D%22height%3A%2027px%3B%22%3E%0A%3CTD%20style%3D%22font-size%3A%20inherit%3B%20padding%3A%205px%3B%20width%3A%2013%25%3B%20height%3A%2027px%3B%22%3E%3CSTRONG%3E%E6%B8%A9%E5%BA%A6%E4%BC%A0%E6%84%9F%E5%99%A8%3C%2FSTRONG%3E%3C%2FTD%3E%0A%3CTD%20style%3D%22font-size%3A%20inherit%3B%20padding%3A%205px%3B%20width%3A%2039.8513%25%3B%20height%3A%2027px%3B%22%3E%3CA%20class%3D%22link-titled%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fsensors%2Fic-digital-temperature-sensors%2Fic-bus-fm-plus-1-degree-c-accuracy-digital-temperature-sensor-and-thermal-watchdog%3APCT2075%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fsensors%2Fic-digital-temperature-sensors%2Fic-bus-fm-plus-1-degree-c-accuracy-digital-temperature-sensor-and-thermal-watchdog%3APCT2075%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EPCT2075%EF%BC%9AI2C%20%E6%80%BB%E7%BA%BF%20Fm%2B%EF%BC%8C%E7%B2%BE%E5%BA%A6%E4%B8%BA%201%20%E6%91%84%E6%B0%8F%E5%BA%A6%20%7C%20NXP%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20style%3D%22padding%3A%205px%3B%20width%3A%20103.149%25%3B%20height%3A%2027px%3B%22%3E%0A%3CUL%3E%0A%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%23333f48%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2016px%3B%22%3E%3CSPAN%3E%E6%8F%90%E4%BE%9BLM75%E7%B3%BB%E5%88%97%E7%9A%84%E5%BC%95%E8%84%9A%E5%88%B0%E5%BC%95%E8%84%9A%E6%9B%BF%E6%8D%A2%EF%BC%8C%E4%BD%86%E6%80%BB%E7%BA%BF%E4%B8%8A%E6%94%AF%E6%8C%81%E5%A4%9A%E8%BE%BE27%E4%B8%AA%E5%99%A8%E4%BB%B6%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%23333f48%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2016px%3B%22%3E%3CSPAN%3E%E7%94%B5%E6%BA%90%E7%94%B5%E5%8E%8B%E8%8C%83%E5%9B%B4%EF%BC%9A2.7%20V%E8%87%B35.5%20V%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%23333f48%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2016px%3B%22%3E%3CSPAN%3E%E6%B8%A9%E5%BA%A6%E8%8C%83%E5%9B%B4%E4%B8%BA-55%20%C2%B0C%E8%87%B3%2B125%20%C2%B0C%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%20style%3D%22height%3A%2027px%3B%22%3E%0A%3CTD%20style%3D%22font-size%3A%20inherit%3B%20padding%3A%205px%3B%20width%3A%2013%25%3B%20height%3A%2027px%3B%22%3E%3CSTRONG%3E%E6%97%A0%E7%BA%BFMCU%3C%2FSTRONG%3E%3C%2FTD%3E%0A%3CTD%20style%3D%22font-size%3A%20inherit%3B%20padding%3A%205px%3B%20width%3A%2039.8513%25%3B%20height%3A%2027px%3B%22%3E%3CA%20class%3D%22link-titled%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fwireless%2Fthread%2Fkinetis-kw41z-2-4-ghz-dual-mode-bluetooth-low-energy-and-802-15-4-wireless-radio-microcontroller-mcu-based-on-arm-cortex-m0-plus-core%3AKW41Z%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fwireless%2Fthread%2Fkinetis-kw41z-2-4-ghz-dual-mode-bluetooth-low-energy-and-802-15-4-wireless-radio-microcontroller-mcu-based-on-arm-cortex-m0-plus-core%3AKW41Z%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EArm%20%C2%AE%20Cortex%20%C2%AE%20-M0%2B%7CKinetis%20%C2%AE%20KW41Z%202.4%20GHz%20%E4%BD%8E%E5%8A%9F%E8%80%97%E8%93%9D%E7%89%99%20Thread%20Zigbee%20%E6%97%A0%E7%BA%BF%E7%94%B5%20MCU%20%7C%20NXP%3C%2FA%3E%3C%2FTD%3E%0A%3CTD%20style%3D%22padding%3A%205px%3B%20width%3A%20103.149%25%3B%20height%3A%2027px%3B%22%3E%0A%3CUL%3E%0A%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%23333f48%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2016px%3B%22%3E%3CSPAN%3E%E7%AC%A6%E5%90%882.4%20GHz%20Bluetooth%20Low%20Energy%20V4.2%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%23333f48%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2016px%3B%22%3E%3CSPAN%3E%E7%AC%A6%E5%90%88IEEE%20Std.%20802.15.4%E6%A0%87%E5%87%86%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%23333f48%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2016px%3B%22%3E%3CSPAN%3EAES-128%E5%8A%A0%E9%80%9F%E5%99%A8(AESA)%EF%BC%8C%E7%9C%9F%E9%9A%8F%E6%9C%BA%E6%95%B0%E7%94%9F%E6%88%90%E5%99%A8(TRNG)%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3C%2FTBODY%3E%0A%3C%2FTABLE%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1110042%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E5%B7%A5%E4%B8%9A%E6%8E%A7%E5%88%B6%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
无评分
版本历史
最后更新:
‎10-27-2020 09:44 AM
更新人:
