about NFC Antenna Pattern
343件の閲覧回数
theo-choi
The back of the NFC antenna pattern in the photo below is designed with a ground pattern. Could you advise on the characteristics this might entail?
Thank you.
277件の閲覧回数
Tomas_Parizek
Hello theo-choi
I know that some customers used similar patterns for better EMI behavior.
Tomas
4 返答(返信)
278件の閲覧回数
Tomas_Parizek
Hello theo-choi
Tomas
293件の閲覧回数
KellyLi
Hello @theo-choi
Could you share the exact type of the IC what you are using? Maybe, some Demo design can be recommended to you for reference.
269件の閲覧回数
theo-choi
The chip in the above picture is an NXP chip, but it's not the one we use in our devices.
Thank you for your interest.
302件の閲覧回数
theo-choi
Connecting the center of the antenna pattern to GND improves the characteristics against power noise.
from 3ALogistics
