Straight forward 14443B protocol like a rs232 port
509件の閲覧回数
hanktan
I'm trying to use a pair of rc531 boards to bridge between the card and reader, and analyze character streams passing between them. There is an app called NFC SPY can easily control 2 android phones to bridge between the card and the reader. I want to know what (cos) commands to set the 531 to behave just output any streams converted from NFC 14443B physical signal without to to identify any card number or Device ID or any poking into the stream. Attached is the NFC SPY bridge data stream result
382件の閲覧回数
Kan_Li
Hi Hank,
There is no such kind of command for your requirement, maybe you have to built a costom application to implement this function.
Have a great day!
Kan
