OM27160A1HN in Linux '. /nfcDemoApp' failed based on document AN13287
651 次查看
Kane_1024
Sorry, I am a newbie, I have a PN7160 module is OM27160A1HN, I follow the document AN13287, from '4.2 Alternative to nxpnfc kernel driver', at first it is smooth, no error in Linux, but when I run to '. /nfcDemoApp poll' when there is this error, I'm not quite sure what causes this
But I run '. /nfcDemoApp --help' is OK
If you can help me, I would be very grateful!
616 次查看
danielchen
HI @Kane_1024
I would suggest you refer to below step-by-step guide on how to run NFC on Raspberry Pi platform.
https://community.nxp.com/t5/NXP-Designs-Knowledge-Base/Easy-set-up-of-NFC-on-Raspberry-Pi/ta-p/1099...
595 次查看
Kane_1024
Hi Daniel,
Thanks for your answer, I followed https://community.nxp.com/t5/NXP-Designs-Knowledge-Base/Easy-set-up-of-NFC-on-Raspberry-Pi/ta-p/1099... but I still get the same error as follows:
## NFC demo ##
## Poll mode activated ##
... press enter to quit ...
terminate called after throwing an instance of 'std::out_of_range'
what(): basic_string::substr: __pos (which is 4294967296) > this->size() (which is 2)
Aborted
By the way, I cloned 'git clone https://github.com/NXPNFCLinux/linux_libnfc-nci.git -b NCI2.0_PN7160'
Is there any solution?Thanks.
BR,
450 次查看
Casper_Hsu
I also encountered the same problem, but it can be solved using a 32-bit operating system
