MFRC63002 & CLRC66303HN NfcrdlibEx1_BasicDiscoveryLoop porting
join_ren
Hello
I‘m porting NfcrdlibEx1_BasicDiscoveryLoop in CLEV6630B+RT1052 . It can read Type A card.
If I replace development board CLRC66303HN to MFRC63002.
I check datasheet CLRC66303HN & MFRC63002 is Pin to Pin.
Question: Does the HW & SW need to be modified ?
Labels (2)
join_ren
Hello
Thanks for your support.  This problem has been resolved.
join_ren
In AN11256 document description “ To setup the main protocol settings for MFRC631, MFRC630 or SLRC610 the “loadprotocol” must be used. ”
How to 'loadprotocol' .  If I use MFRC630.
Thanks.
estephania_mart
But there is also the mention there that for MFRC631 and MFRC630 the supported protocol numbers stay the same. So for both derivates the “PHHAL_HW_RC663_RXTX_xxx” table, in the phhalHw_Rc663_Int.h file doesn’t need to be changed.
Still, in the SDK you can check the phhalHw_Rc663_Cmd_LoadProtocol .
Estephania
estephania_mart
you will need to perform some modifications, still, I believe that you can find them in the application note AN11256, could you please check it and verify if this is what you were looking for?
Estephania
