MFRC522 Crystal power dissipation
a_vanbaalen
I'm going to use the MFRC522 in a design (I know there is a new version recommended but the client really wanted to use this chip).
But when finding a crystal for it, the datasheet specifies a maximum power dissipation of 100mW, but I think and hope this should be 100uW as there are no crystals available that I know of that can dissipate 100mW.
Allard van Baalen
Sabina_Bruce
Hi Allard,
You are correct, there is a typo in the document it should be uW. Thank you for noticing this, I will pass on the information to have it corrected.
Sabina
