Can I change NFC detecting range on CLRC663 ?
807 次查看
cjujh
Hello.
I've been making NFC module using CLRC663 IC on CLEV6630B v2.0 Board nowadays.
I'd wanted to change the NFC detecting range by only use software setting.
So I'd checked datasheet and modified below register and 0x28 and 0x2A registers too.
But, it was operated same range.
Is it possible to change the range? How can I do that?
Thank you.
标签 (2)
641 次查看
Kan_Li
I am sorry, but the operating range depends on the antenna size, please refer to the following for details.
You may refer to NFC Antenna Design 1: Which Antenna for what purpos|NXP  for more details.
Hope that helps,
Kan
