In the MBDT_S32K1xxx toolbox, almost all of the examples are a top-model. When I use model references, the generated code is not successful. Does the toolkit support model references? What should I do?
Example:
Error when generate code:
See attachment for example model.
Why does my License always not exist? When I checked the video on the official website, I found that I was short of several files. I wonder where you downloaded these files
Can you leave a contact information?
My personal email: 1045759673@qq.com
NXP官网下载页面有个TAB “License” ,在这个TAB生成License并且保存为license.dat,将license.dat放置在工具箱安装目录的lic文件夹下。或者安装“NXP Support Package S32K1xx”工具(官网和Matlab附加功能管理都有下载),然后在Matlab运行NXP_Support_Package_S32K1xx.m,按顺序安装激活工具箱。
hello Dee Alen:
我就是这种操作,在Matlab附件功能管理下进行操作的。但是总是上报license Error - 9:表示license invalid。我就那么纳闷了,不知道哪里错了,我就执行了这三个操作,你呢?
确认MAC地址是否正确:
不行重新return再生成license。
第四步才是激活,你好像没做!!!
hi Dee Alen:
我已经搜擦到license,但是还是 不行,上报license无效
我把我的license 附录上去你看看吧
能不能提供下邮件1045759673@qq.com 我这里真心不知道哪里有问题了
不是用的是磁盘号,怎么是物理地址呢?
我也按照你的方法查询了下:
结果:Sorry, no licenses were found that matched your search.
还有我生成的license中是由于我的中文名字导致的,可以账户名字更改部过来。 这个有没有影响
如果没有网络,是否可以激活的,,,,(禁网)
