httpsrv example on FRDM-K64F
1,277 次查看
mittymcdoogle
I've tried running the httpsrv example code found in the MQX 4.2 package on my K64 freedom board. However, when I try to use the command prompt to ping the board, I fail to receive any response.
What can I do to get this demo working on my board?
Mitty
标记 (3)
876 次查看
DavidS
Hi Mitty,
Try the following to cause your frdm-k64f Freedom board to do a DHCP:
Starting HTTP server No.0 on IP 192.168.1.202, port 80...[OK]
Shell (build: Jul  6 2015)
Copyright (c) 2013 Freescale Semiconductor;
shell>
shell> ipconfig dhcp
Bind via dhcp successful.
shell>
shell> ipconfig
Eth#     : 0
Link     : on
MTU      : 1500
MAC      : 00:00:5e:a8:01:ca
IP4      : 10.0.1.187 Type: DHCPNOAUTO
IP4 Mask : 255.255.255.0
IP4 Gate : 10.0.1.1
IP4 DNS  : 10.0.1.1
IP6      : DISABLED
Link status task stopped
shell>
shell> ping 10.0.1.1
Pinging 10.0.1.1:
Press [q] to cancel.
Reply from [10.0.1.1]: time=8ms
Reply from [10.0.1.1]: time=3ms
Reply from [10.0.1.1]: time=4ms
shell>
David
9 回复数
876 次查看
danielchen
Hi Mitty:
I think you can check the jumper settings in your board. Please refer to section 9.3 FRDM-K64F in MQX_Getting_Started.pdf.
Have a nice day,
876 次查看
mittymcdoogle
Hi Daniel,
I don't see any jumper settings for Ethernet - were you just asking that I check my jumpers versus the default jumper configuration?
Mitty
876 次查看
danielchen
Hi Mitty
Yes, the default jumper configurations is OK
I can run this demo in FRDM-K64 without problems.   please see the following picture, 192.168.1.10 is my PC's IP
876 次查看
mittymcdoogle
Hi Daniel,
I have checked all of my jumpers to make sure that they are set to the default position. I am still unable to ping the board or see the board through my router.
877 次查看
DavidS
Hi Mitty,
shell>
shell>
shell> ipconfig
Eth#     : 0
Link     : on
MTU      : 1500
IP4 Gate : 10.0.1.1
IP4 DNS  : 10.0.1.1
IP6      : DISABLED
shell>
Pinging 10.0.1.1:
shell>
David
876 次查看
mittymcdoogle
I plugged a new board into my router and I'm able to connect after using that command.
Thanks!
876 次查看
DavidS
WowWho!!!
Thanks for update.
David
876 次查看
mittymcdoogle
Hi David,
When I type "ipconfig dhcp", I receive the following error message:
Error during dhcp bind 00001d04!
Mitty
876 次查看
danielchen
Hi Mitty:
Check that the devices are in the same local subnet. Or, if they are in different subnet, make sure the gateway configuration in RTCS is correct. When RTCS tries to send an IP to different network, it sends the frame via gateway.
If it does not help, could you change another board and try it again?
