how to do linker setup
614件の閲覧回数
sudhakarp
Contributor V
hi,
i am using FRDMk64, KDS 2.0 and KSDK 1.1.0 example.
     actually my code should work following method.
just assume 2 example code( hello word and timer example code).
this both code will have separate linker file setting, i want to jumb from hello word example to timer example code.
so for that which type of linker file setting i want to do..?
i tried following setting but its not working..
hello example linker setting:
MEMORY
  m_interrupts          (RX)  : ORIGIN = 0x00000000, LENGTH = 0x00000400
  m_flash_config        (RX)  : ORIGIN = 0x00000400, LENGTH = 0x00000010
  m_text                (RX)  : ORIGIN = 0x00000410, LENGTH = 0x0000FBF0
  m_data                (RW)  : ORIGIN = 0x1FFF0000, LENGTH = 0x00010000
  m_data_2              (RW)  : ORIGIN = 0x20000000, LENGTH = 0x00030000
timer example linker setting:
MEMORY
  m_interrupts          (RX)  : ORIGIN = 0x0000FBF0, LENGTH = 0x00000400
  m_flash_config        (RX)  : ORIGIN = 0x0000FFF0, LENGTH = 0x00000010
  m_text                (RX)  : ORIGIN = 0x00010000, LENGTH = 0x000EFBF0
in hello example code i am calling following function for jump into timer ex.code
static void (*appl_ptr)( void ) = 0xFBF0;
i am caling appl_ptr();
i am loading both code throught PE multilink device. but nothing was working. hello example also not working.
can you give some idea.
regards,
sudhakar p
ラベル(2)
353件の閲覧回数
Carlos_Musich
Hi Sudhakar,
I did something similar in CW10. I configured linker files as below:
MEMORY
  m_interrupts    (rx) : ORIGIN = 0x00000000, LENGTH = 0x1E0
  m_cfmprotrom     (rx) : ORIGIN = 0x00000400, LENGTH = 0x10
  m_text         (rx) : ORIGIN = 0x00000800, LENGTH = 0xA000 - 0x800        /*Bootloader space*/
  my_text         (rx) : ORIGIN = 0x0000A000, LENGTH = 0x7F800 - 0xA000    /*Application space */
  m_data        (rwx) : ORIGIN = 0x1FFF0000, LENGTH = 64K                /* Lower SRAM */
  m_data2       (rwx) : ORIGIN = 0x20000000, LENGTH = 64K                /* Upper SRAM */
MEMORY
  m_interrupts    (rx) : ORIGIN = 0x0000A000, LENGTH = 0x1E0
  m_cfmprotrom     (rx) : ORIGIN = 0x0000A400, LENGTH = 0x10
  m_text         (rx) : ORIGIN = 0x0000A800, LENGTH = 512K - 0x800 - 0xA000
Then I looked for the entry point address of application 2 in .map file.
.text.__thumb_startup
                0x0000a87c       0x30 ./Project_Settings/Startup_Code/__arm_start.o
                0x0000a87c                __thumb_startup
Finally I used the instruction below to jump to the second application.
asm("bl 0x0000a87c"); //Jump to entry point in application 2
I hope this helps,.
Carlos
