cdc virtual_com example not working on Kwikstik
1,146 次查看
mpc8377e
I am trying to run CDC virtual_com example on K40 Kwikstik board. I can send data from host (windows xp) to device and can print the data received but the data sent from device is not received by the host.
The same example works fine on k40 Towermoulde.
Any solutions for this problem.
Raghu
标记 (1)
775 次查看
BlackNight
good news: my problem has been solved with the attached .inf file :smileyhappy:.
BK
4 回复数
775 次查看
c0170
Senior Contributor III
Hi mpc8377e,
does your problem persist or any progress made? I'll test that example and get back to you with the result.
MartinK
775 次查看
BlackNight
Hi there,
for information: I have the same problem: I can send data from the host to the KwikStik, but cannot send from the KwikStik to the host:
https://community.freescale.com/message/112100#112100
BK
776 次查看
BlackNight
BK
775 次查看
MarkP_
Contributor V
same problem with MQX4.0 and CW10.4.
Does that inf-file change fix it?
Where can I get it?
~Mark
