Hi all,
We are using AR4100 chipset in our platform for Wi-Fi connectivity. But the range of the Wi-Fi module is very low(~10 meter only).
We have set the power mode to “Max Performance” and tested using different TX power values(0, 15, 60 using the shell command wmiconfig –settxpower xx). But we didn’t experience any change in the Wi-Fi range. Also it seems the command to get TX power is not implemented in the driver.
We would like to know:
Other Details
OS : MQX 4.0.2
Platform : K60
Akhil
Hello Akhil,
Unfortunately we cannot provide a comprehensive answer; AR4100 is developed by our partner Qualcomm-Atheros, you need to contact Qualcomm directly.
In addition, please check the below documents:
http://cache.freescale.com/files/wireless_comm/doc/prod_brief/AR4100_IoT_Wireless_Specs.pdf
http://cache.freescale.com/files/wireless_comm/doc/prod_brief/AR4100_IoE_System_Spec.pdf
http://www.farnell.com/datasheets/1791001.pdf
http://cache.freescale.com/files/wireless_comm/doc/user_guide/TWRWIFIAR4100UM.pdf
http://cache.freescale.com/files/wireless_comm/doc/support_info/TWRWIFIAR4100LAB.pdf
Have a nice day!
Sol
Dear Sol,
Thank you for the details.
I would appreciate it very much, if you provide some more contact details(technical) to communicate with Qualcomm.
Thank you.
