I'm attempting to test the SSI callback capability of the MQX web server. I had this working under MQX 4.0 but I can't get it to work under 4.1. I'm using the same code and web page I used in 4.0 so I'm really not sure why it doesn't work.
I have created the SSI function, link table, and am passing that into the web server.
const HTTPSRV_SSI_LINK_STRUCT ssi_tbl[] = {
{ "ssiTest", ssi_test},
{ 0, 0} // DO NOT REMOVE - last item - end of table
static _mqx_int ssi_test(HTTPSRV_SSI_PARAM_STRUCT* param)
printf("SSI test func called\n");
HTTPSRV_PARAM_STRUCT web_srv_params;
extern const HTTPSRV_CGI_LINK_STRUCT cgi_tbl[];
extern const HTTPSRV_SSI_LINK_STRUCT ssi_tbl[];
_mem_zero(&web_srv_params, sizeof(HTTPSRV_PARAM_STRUCT));
web_srv_params.af = AF_INET;
web_srv_params.root_dir = "tfs:";
web_srv_params.index_page = "\\WebTest3.shtml";
web_srv_params.max_ses = 1;
web_srv_params.use_nagle = FALSE;
web_srv_params.script_stack = 2750;
web_srv_params.server_prio = 7;
web_srv_params.script_prio = 7;
web_srv_params.cgi_lnk_tbl = (HTTPSRV_CGI_LINK_STRUCT*) cgi_tbl;
web_srv_params.ssi_lnk_tbl = (HTTPSRV_SSI_LINK_STRUCT*) ssi_tbl;
return (HTTPSRV_init(&web_srv_params));
I have my HTML file named as a .shtml file. I have SSI calls in my HTML code in the format specified in the RTCS users guide.
<% ssiTest:parameter %>
When I load the web page it just appears to skip right over the SSI and never calls my C code function.
Does anyone have any idea why this doesn't work? It's probably something simple I'm missing since it used to work in MQX 4.0.
Sean
已解决! 转到解答。
there is a bug in MQX 4.1.0.1 preventing correct invocation of SSI with parameter. To fix it you have to do following:
char* separator;
table = (HTTPSRV_FN_LINK_STRUCT*) server->params.ssi_lnk_tbl;
/* Set separator to null character temporarily. */
separator = strchr(msg_ptr->name, ':');
if (separator != NULL)
*separator = '\0';
user_function = httpsrv_find_callback(table, msg_ptr->name, &stack_size);
*separator = ':';
/* Option No.1b - Run User SSI function here. */
if ((user_function != NULL) && (stack_size == 0))
httpsrv_call_ssi((HTTPSRV_SSI_CALLBACK_FN) user_function, msg_ptr);
httpsrv_ses_flush(msg_ptr->session);
break;
This should fix the problem you are experiencing.
Karel
I tried installing the patch but it still doesn't work.
If I set a break point in httpsrv_supp.c httpsrv_sendextstr() I can see it hitting the lines:
_msgq_send(msg_ptr);
/* Wait until SSI is processed. */
_task_block();
The check for shtml in httpsrv_sendfile() is also true when I step through
if ((0 == strcasecmp(ext, ".shtml")) || (0 == strcasecmp(ext, ".shtm")))
Though I never see httpsrv_call_ssi() being called. I'm not real familiar with this area of MQX code but it seems like that is something that should be called.
However I have noticed that if I remove the ":paramater" part of the <%function_name:parameter%> and just put <%ssiTest%> in my shtml file that it will call my SSI function. It seems to work normally in this case but I lose that ability to pass in a parameter.
If there is anything else I should try please let me know.
Sean
char* separator;
*separator = '\0';
*separator = ':';
break;
Karel
