Question about lightweight message queue:
1,162 次查看
dcooper
I am trying to use _lwmsgq_init(location, num_messages, msg_size) to setup a message queue.
In this case I only need the queue to hold one message at a time and the messages may be a 100+ bytes.
I am using the following to setup the queue:
#define UARTQ_NUM_MESSAGES      1
#define UARTQ_MSG_SIZE                50        //In uint32s, allow for 200 byte messages
#define UARTQ_SIZE                          ((sizeof(LWMSGQ_STRUCT)/sizeof(_mqx_max_type)) + (UARTQ_NUM_MESSAGES * UARTQ_MSG_SIZE))
uint32_t g_uart_tx_msgq[UARTQ_SIZE];
result = _lwmsgq_init((void*)g_uart_tx_msgq, UARTQ_NUM_MESSAGES, UARTQ_MSG_SIZE);
I seem to have some confusion around the msg_size parameter.
If I use the code above code, it does not work.  After receiving a message from the queue the code ends up in the __boot_exception() while(1).
If I set UARTQ_MSG_SIZE to some smaller number (<= 25) and simply allocate the message queue as uint32_t g_uart_tx_msgq[1000], the code runs as expected for messages much larger than 8 bytes.
Is there a limit on the message size for lightweight message queues, or does anyone have other insight into what I am seeing.
David
809 次查看
soledad
Hello David,
Which MQX version are you using?
Soledad
809 次查看
dcooper
Soledad
Can you provide any insight on this issue?
David
809 次查看
dcooper
The Release Notes in the MQX/doc folder indicate 4.1.0.
