Programming FRDM-K64F with Keil
1,473件の閲覧回数
vuklesi
I have recently started working with MQX 4.2 on K64F. I use Keil uVision 5 to build my application on top of the IEEE 1588 demo project. I need a very tightly timed position control for which I use the PIT module (1ms period), however, installing a regular ISR gave me a relatively large activation jitter. I found instructions on how to use a kernel ISR instead (I had to recompile MQX with MQX_ROM_VECTORS set to 0). The jitter in activation time of the ISR reduced greatly, but now the board is acting differently.
When I compile/load my project with:
_int_install_isr (INT_PIT0, PIT_IRQHandler, 0);
everything is OK, and I can reset the board multiple times and see the same code running every time.
_int_install_kernel_isr (INT_PIT0, PIT_IRQHandler);
after the load finishes, I restart the board and the code runs. However, if I restart the board, no code is being run anymore until I perform another load.
Does anyone have an idea why this is happening and how to overcome this? I would really have to use kernel ISRs for my application.
Thank you very much.
999件の閲覧回数
danielchen
Hi Vuk:
I don't understand "after the load finishes, I restart the board and the code runs. However, if I restart the board, no code is being run anymore until I perform another load.".  Do you mean the code can't run if restart the board?  you need to perform another load ?If this is the case, I think it is a normal behavior,  because the vector table is in RAM, the stored information is lost if power is removed.
_int_install_kernel_isr can be used only if the vectors are in RAM. You can also install the user kernel_isr when MQX_ROM_VECTORS is set, but then you cann't use the _int_install_kernel_isr function, you need to modify the ROM vector table itself, as it resides in the flash in this configuration
mqx/source/bsp/frdmk64f/vectors.c
You can have a try, hope it helps.
9 返答(返信)
1,000件の閲覧回数
danielchen
Hi Vuk:
999件の閲覧回数
vuklesi
Hello Daniel,
Thank you very much for a prompt response. I was not aware that MQX_ROM_VECTORS set to 0 will not allow the created binary file to be runnable anytime.
Could you point me to any documents to help with customizing the vector table?
Thank you very much!
999件の閲覧回数
danielchen
I have a short question, do you load your image to SRAM, or to Flash ?  If you load to SRAM, I think the vector table will lost after reboot.
999件の閲覧回数
vuklesi
Daniel,
I am still having trouble with this. So, I have modified the vector table in vector.c as in these screenshots:
Additionally, in one of the single-shot tasks, I call:
_int_install_kernel_isr (INT_PIT0, interpolationPeriodRoutine);
_bsp_int_init ((IRQInterruptIndex)INT_PIT0, 0, 0, TRUE);
But this does not give me the ability to run my application after restarting the board. If I remove the call to _int_install_kernel_isr, and leave only _bsp_int_initthen my ISR never gets activated, which makes me think that I am not modifying the vector table correctly. I should probably note that I do rebuild MQX projects after changing anything in the vector.c file. Could you please point out what am I doing wrong?
Thank you very much for your help.
999件の閲覧回数
danielchen
Here attached my code.
999件の閲覧回数
vuklesi
Daniel,
Thank you very much for your efforts. I have the default vector table and I used to have several tasks that initialize the peripherals that I need. When I converged all that code into one task, even though nothing significant was really changed, my problem got fixed somehow. So, just putting all initialization into one task fixed my issue. I am not sure why this is the case, but this solved the issue.
Thank you for helping around this issue.
999件の閲覧回数
danielchen
Hi Vuk Lesi:
Sorry for the late response.
I double checked your questions.  I have some doubts about your results. The _int_install_kernel_isr can work well if I reboot the devices. Why your result is fail after reboot?   _int_install_kernel_isr can be used only if the vectors are in RAM. You need to place this code in user_config.h and rebuild the bsp and psp libraries.
#define MQX_ROM_VECTORS          0
Though the vector is in RAM, it will disappear after power lost, it will reinstall the kernel isr to RAM after reboot. Sorry maybe I didn't explain it clearly in my last reply.
I did a quick test with _int_install_kernel_isr on TWR-K60D100M board, and the result is OK. I attached my code.
999件の閲覧回数
vuklesi
Daniel,
Thank you very much for your help. I use the fromelf image converter to produce a .bin file at the end of building my project, which I copy to the flash memory of K64F.
Thank you for the screenshot. I suppose I should supply the name of my ISR for ivINT_PIT0, not ivINT_Hard_Fault. However, I also need to set the NVIC correctly, besides manually changing the vector table, right? I have tried just calling _bsp_int_init((IRQInterruptIndex)INT_PIT0,1,0,TRUE); but that does not work. Could you please explain what else do I need to do besides defining my ISR and adding its name to the vector table?
Thank you very much for your time.
999件の閲覧回数
danielchen
Please refer to the below code
