Dear Sir:
Recently I am doing a project about Multi-tasking programming based on MQX.The data would be transferred via TCP,UDP or UART.Then the data would be handled by a task.I want use Multi-tasking programming,so the chip can receive data while process data.
So I want an example about Multi-tasking programming.
That's all.Thank you!
解決済! 解決策の投稿を見る。
Another good example Huang is:
C:\Freescale\Freescale_MQX_4_0\rtcs\examples\shell
David
David
Great , thank you very much!
There are demo applications available in MQX4.0_RTM release, e.g the havc. You can have a look at this demo which is located at C:\Freescale\Freescale_MQX_4_0\demo\hvac if you install in the default path.
I have seen the example. But i is so complexed.Can you tell me what is the function of the demo hvac?Thank you!
Hello huang kai,
this explains what does HVAC do although it's targeted for Coldfire board:
http://cache.freescale.com/files/soft_dev_tools/doc/support_info/MQXTUTORIALLAB.pdf
Please run the demo and explore hvac's code before asking another question. :smileywink:
MartinK
Dear Sir:
This example is very complexed.Can you give me a simple example about Multi-tasking programming
thank you
