Mac Address
1,256件の閲覧回数
netra
How to use own mac address instead of using ENET_get_mac_address().
I am using mcf52259 and mqx3.5
Thanks in advance,
nisha
727件の閲覧回数
butok
For example:
_enet_address    enet_address = { <Put here your mac address> };
ipcfg_init_device (BSP_DEFAULT_ENET_DEVICE, enet_address);
4 返答(返信)
728件の閲覧回数
butok
For example:
727件の閲覧回数
netra
Yes, I did this and it works too,
Is there any way to check that whatever mac address set by me is set in controller??
Can we change mac address in run time ??
Andrey thanks for your reply.
Thanks in Advance,
Nisha
727件の閲覧回数
butok
Hi Nisha,
You can try ipcfg_get_mac() or ENET_get_address().
>>.Can we change mac address in run time ?
Do release of the ENET device, and after do its initialization with new mac address.
Cheers,
Andrey Butok
727件の閲覧回数
netra
This is  the code which i wrote to extract mac address .The mac address replied is always same , although i change the mac address the way u asked me to do in previous post .Ethernet connection is created using the mac address which i give , but while checking the mac address, it doe not match with the value which i gave.
uint_32 rtn;
    IPCFG_IP_ADDRESS_DATA    ipaddr;
    char mac[6];
    ipcfg_get_mac(IPCFG_default_enet_device,mac);
    printf("%x:%x:%x:%x:%x:%x\n",mac[5],mac[4],mac[3],mac[2],mac[1],mac[0]);
