Check the below thread and please let me know if this helps!!
Using U-boot as MQX bootloader
Sol
Hi soledad,
Well actually I had this as an under-question, I wanted to know if I can avoid using U-boot.
What I would want is a bootloader (hopefully based on MQX.. (what does MQX use to load itself, I havent studied) which can load MQX
or Linux, and be royalty free or non restrictive license so that one can modify the sources without releasing custom changes.
Unfortunately we at this moment we don't have a solution like you need.
Sorry for any inconvenience.
Sol
