MQX 4.2 Project Wizard can't be installed
1,065 次查看
norbertoj
I have some problems to add MQX 4.2 to Codewarrior 10.6. I used the option Install new software, this said me that MQX patch were added successfully; however, when I wanted to create a new MQX 4.2 Project, it was not of my options in File/New. I have tried everything like as reinstalling  codewarrior, and it was the same result.
My Codewarrior is 10.6 Special Edition Offline.
767 次查看
ZhangJennie
CW10.6 can support MQX4.2 without problem.
please go to IDE menu "help", "install new software" to install related MQX4.2 plugins.
this should enable MQX4.2 from menu:
can it help you?
Jennie Zhang
4 回复数
768 次查看
ZhangJennie
can it help you?
Jennie Zhang
767 次查看
norbertoj
OK, After repeating three times your instructions; finally, I could install MQX 4.2 Wizard :smileyhappy:
767 次查看
ZhangJennie
that's nice. congratulations!
Jennie Zhang
767 次查看
norbertoj
I did it, but it still missed, I can't see MQXN 4.2 Project Wizard.
