How to stop all interrupts in MQX
998 次查看
Mohsin455
Hi All,
            I want to know how to disable all the interrupts (even systick) from a task in MQX. I am using K60N512. Can anyone please provide some information ?  I have looked into some of the posts in the forum and they discuss on how to disable only certain interrupts not all.
Mohsin
标记 (3)
452 次查看
anthony_huereca
You can use _int_disable() and _int_enable().
Or put these macros somewhere in your code, which can be used to disable/enable interrupts at the core.
#define EnableInterrupts asm(" CPSIE i");
#define DisableInterrupts asm(" CPSID i");
453 次查看
anthony_huereca
