How can I program the inactive polarity of PCS0 (CS0 for SPI channel) from within MQX?
855 次查看
alfredolopez
I have a TWR-K60F120M . I am using the SPI port and it works fine but I need to change the polarity of PCS0. I need it as inactive
at low level.
How can I program this option from within MQX?
5 回复数
645 次查看
soledad
Hi Alfredo,
What MQX version are you using???
Are you using the MQX SPI drivers???
Sol
645 次查看
alfredolopez
Hi Soledad,
I am using MQX 4.0 version.
Yes I am using MQX SPI drivers.
Regards.
Alfredo
El 08/05/2014 15:18, soledad escribió:
Freescale Community <https://community.freescale.com/>
reply from soledad
<https://community.freescale.com/people/soledad?et=watches.email.thread>
in /MQX Software Solutions/ - View the full discussion
<https://community.freescale.com/message/401676?et=watches.email.thread#401676>
645 次查看
soledad
You need to modify the Driver, please check the SPI.h and SPI.c files that are located at the path  C:\Freescale\Freescale_MQX_4_0\mqx\source\io\spi
You can modify this files according your needs.
Sol
645 次查看
alfredolopez
Thank you, Soledad.
I should prefer not to have to modify the Driver, but I think that it
will be the only option.
Regards.
Alfredo
reply from soledad
<https://community.freescale.com/message/401768?et=watches.email.thread#401768>
645 次查看
pbanta
Hi Alfredo,
I'm not sure about MQX 4.0, but in MQX 4.1 there is an option to install a callback function for managing the CS line from your application.  The example (Freescale_MQX_4_1/mqx/examples/spi) shows how to do this.  I used this technique to successfully change the polarity and I didn't have to change the driver code.  In my callback function I used lwgpio to change the state of the CS pin.
