How can I add Processor Expert to an existing MQX BSP, using KDS 3.2
785 次查看
robertyork
I have imported a BSP for the K70 tower board (bsp_twrk70f120m) and want to work off of that as my baseline for a new board, but it doesn't have Processor Expert enabled. In CW, when doing the same thing, I'm fairly sure PE came already set up for the BSP.
How can I add PE to this BSP? Is there another K70 tower board BSP with PE already set up I can use?
653 次查看
robertyork
No, that doesn't really help.
I understand it's supported in CW or IAR, but we're not using those tools. I'm trying to keep a consistent tool chain together for the Kinetis parts I use. When NXP moved away from CW, they moved to KDS. I need the same functionality that I had before. I don't want to purchase and move to an entirely new tool set just because NXP can't get their tools together. I need a company that provides an end-to-end solution, not a patch work of random different tools that work fine one with one part, but not a different part in the same family.
652 次查看
danielchen
Hi Robert
PE support with KDS is enabled in KSDK.  But current KSDK not support K70.
I think Codewarrior is a good solution to enable PE support with MQX for K70.
You also have an option to try to use Processor Expert driver suite. I attached a document about using Processor Expert to Generate Code for IAR, it may help for you to generate code for KDS. I hope it helps.
