Encountered a problem on the RTCS and MQX.
931件の閲覧回数
jetli
In my project, I encountered a problem:
In Kinetis K66,my board with a 16MB SDRAM,I need change ram pool to SDRAM, so I use this code at the first task:
_mem_pool_id test_id , old_id ;
test_id = _mem_create_pool((void *)0x08000000,(_mem_size)0x00A00000);  //10MB
old_id = _mem_set_default_pool(test_id);
so , I can use function "malloc" in my project allocate memory at address 0x08000000;
but, I encountered a problem use this with RTCS , when i set SDRAM address at "0x70000000", "0x80000000","0x88000000", RTCS working properly , but when I  set SDRAM address at "0x08000000", RTCS will not working properly,but the rest of the system work all normal。
ps:MQX and RTCS version is 4.2.0
2 返答(返信)
727件の閲覧回数
DavidS
Hi jet,
It might actually be the memory map accesses that are (or are not) allowed.
Look at the Reference Manual Table 5-1 "System memory map" on Chapter 5.
The 0x0800_0000 - 0x0FFF_FFFF allows only core access.
The other addresses that work for you allow "All masters".
David
727件の閲覧回数
jetli
Hi David,
Thanks  alot , Your reply to my problem.
