CAN source address destination address
819 次查看
davidsa
My CAN receiver has a SA of 0x1ff, in your horrible documentation you refer to as TX_identifier.
I can receive messages from five different CAN connections. According to what ever the data
may be I may need to reply to separate Destination addresses. I do have the software running
with a specific TX_identifier and a specific RX_identifier and their assigned mailbox number.
1) Do I need a different mailbox for each address I need to reply to.
2) Is there a way to at will change the destination address I am trying to send a message to?
标记 (1)
658 次查看
danielchen
Hi David:
I think you use a different mailbox for each address is a better solution to avoid conflict.
In freescale demo, there are two nodes, each node has a RX_identifier and TX_indentifier. So if you have five different CAN connections, you can define more nodes.
#if NODE==1
    RX_identifier = 0x123;
    TX_identifier = 0x321;
    RX_remote_identifier = 0x0F0;
    TX_remote_identifier = 0x00F;
#else if NODE ==2
    RX_identifier = 0x321;
    TX_identifier = 0x123;
    RX_remote_identifier = 0x00F;
    TX_remote_identifier = 0x0F0;
#else if NODE == 3
#endif
658 次查看
davidsa
Thank you for the reply. So I would assume that each node would have its own
interrupt service routine and so on?
This of course would make the mask more difficult. For example if I receive a
message from CAN-ID 1ff and I need to reply to 1ff I cannot mask out 1ff so
I would be receiving my own message. How would I get around this?
David
658 次查看
danielchen
If I understand your requirements correctly, you can let different ID enter different mailbox. you do not need to use mask bits
