Bug Report: I2C driver in MQX 4.1.1 will not compile for K70
691 次查看
chrissolomon
I am trying to get MQX 4.1.1 to compile - I have had 4.1.0 going with the same settings.
I am building for a product with a MK70FN1M0VMJ12 processor.
The problem seems to be that the new I2C driver relies on I2C_FLT_SSIE_MASK, which only seems to be defined in the MK21F12.h header file.
I have had a look at the K70 documentation, and I am not sure how to go about fixing it.
Any thoughts?
Chris
标记 (3)
525 次查看
danielchen
Hi Chris:
I can compile the library and i2c demo, can you double check it, how to reproduce your issue
526 次查看
danielchen
Hi Chris:
523 次查看
chrissolomon
Hi Daniel,
sorry, yes you're right - in the bsp makefile i2c_int_ki2c.c had been changed to i2c_int_ki2c_legacy.c - I missed that change, and that was the source of the problem.
Thanks for the swift response, sorry to have cried wolf!
Chris
