Hi wei lei:
MQX Lite does not inlcude any peripheral drivers. I would suggest you add your PWM driver by PEx LDD.
Please follow below link for how to generate PWM signal using MQX, although it is for Standard MQX, the integration with Processor Expert should be very similar.
How to generate PWM signal using MQX
