time base asm
time base asm
283230333
I got a example project from the support. There are some code which I don't  know the function of the code in the project. The code is below.
# tbs_main_asm.s - Time Base example
# Rev 1 Aug 27 2004 S Mihalik
# Copyright Freescale Semiconductor, Inc 2004 All rights reserved.
.globl tbs_main_asm
.text
tbs_main_asm:
                      # INITIALIZE TIME BASE=0
  e_li      r4, 0       # Load immediate data of 0 to r4
  mttbu   r4    # Move r4 to TBU
  mttbl   r4          # Move r4 to TBL
  # ENABLE TIME BASE
  mfhid0  r5    # Move from spr HID0 to r5 (copies HID0)
  e_li      r4, 0x4000  # Load immed. data of 0x4000 to r4
  or      r5, r4, r5  # OR r4 (0x0000 4000) with r4 (HID0 value)
  mthid0  r5          # Move result to HID0
                      # EXECUTE SOME CODE
  e_nop
  e_nop
  e_nop
  e_nop
                      # RECORD TBL
  mftbl   r5          # Move TBL to r5 to store TBL value
  e_li r4, 0
  e_li r5, 0
  mtmsr r4
  mfmsr r4
  wrteei 1
  mfmsr r5
  se_blr                 # (Set a breakpoint here and read r5)
martin_kovar
the functionality of this code is comprehensibly described in the code comments.
First stage initialize registers TBU and TBL to value 0. Second stage writes 1 to TBEN bit. This enables Time Base (counter implemented in core). Then four nop instructions are executed and value in TBL register is copied to the register R5.
At last R4 and R5 are set to 0, MSR register is set to 0 and wrteei enables interrupts. Last instruction jumps to the address which is in LR register.
Martin
martin_kovar
Martin
283230333
Thank you very much for your reply. I also want to know the function of this code , what kind of role it can achieve? I can't find any information from the reference manual of MPC5644A. Could you give me some reference documents ? Thank you very much again!
martin_kovar
in general it can be used for example for time measuring. In fact Time Base is very precise counter which is implemented in the core. In your case I am not able to tell you why is this code used in your project because I do not have it.
If you want some information about time base, try to look at the core reference manual.
http://cache.freescale.com/files/32bit/doc/ref_manual/e200z4RM.pdf?fsrch=1&sr=1&pageNum=1
Martin
