cannot install CodeWarrior for MPC55xxMPC56xx v2.10.exe
niz
When I was trying to install the "CodeWarrior for MPC55xxMPC56xx v2.10.exe", I cannot install it with admin mode, it always show the wizard was interrupted before Code Warrior ....could be complete:
petervlna
The CW 2.10 will run on winXP or older.
Peter
niz
Hi Peter
Thanks for the info.
Is there any IDE I can use for developing MPC5566 on Windows 11?
I need a basic build environment so that it can build an executable.
Thanks a lot for your help
Ni
petervlna
Not one I know about.
You will need to use winXP emulator on your PC to get it running,
Peter
niz
Hi Peter
Do you know if there is any where we get the SDK for devices drivers in C code format?
Best
Ni
petervlna
Not sure which SDK you have in mind. As far as I know there was only MCAL drivers.
Peter
niz
I am running on Windows 11 Enterprise
stanish
I'd suggest you to try to install CW with installer switched in WinXP compatibility mode:
