I'm using MPC5748G-GW-RDB and trying to debug a sample code from SDK using PE micro, and facing the below error.
Warning : Device is not detected or may be censored. Please check connections or please enter password in GDB server parameters with in debug configurations using the flag -uncensoredpassword=n, then restart the debug session.
MPC5748G-GW-RDB DEVKIT-MPC5748G
Please give me the assistance regarding this.
Have you erase the micro? I expect you have reset escalation due to active SWT_0 with default timeout 300ms (15 resets x 20ms).
Micro will then enter into the reset escalation and can recover only via power on reset.
Have a look at following thread on reset escalation recovery with PEMicro:
Peter
Thank you, @petervlna,
I'm really not sure of reset escalation, Facing the above error only when using PE micro debugger, with Micro USB connection, Flashing and debugging looks fine.
