A couple of questions about two SBC registers in the RM:
What is the meaning of RSTb_ext and RSTb and the difference between them as they are always set to 1 whatever the reset reason is ( microcontroller or SBC ) ?
Also, is it possible to know that an SPI reset request was the reason for an SBC reset ?
Thanks in advance,
Ahmed
WD_answer register implements RSTb which indicated reset cause by WD.
Diag_FS1 - RSTb_ext Report an external reset cause by device external to SBC. For example cased by MCU.
Could you point me to SPI reset request in Datasheet?
Peter
