I install the update14 and open the RTM3.03 SDK demo project in S32DS , but every demo seems have SDK path error. If I build a new application project myself, the SDK works well. How to solve this problem?
how do you open the project? The best way is to use File -> New -> S32DS Project from Example.
Then select Project -> Generate Processor Expert Code (or click on the icon in Components window) and build the project. You should not see a problem in this case.
Lukas
